HI, Thanks for your replies.
Yes I already had the service manual but it doesn't describe how to use the RATIO A/B or exactly what it does?
However it doesn't do what I hoped it did, ie, measure the timing difference between a pulse applied to port A and sometime later Port B (which is what I need)
Instead I found this on the Fluke website:-
RATIO A/B
To find the ratio between two input frequencies, the counter counts the cycles on two
channels simultaneously and divides the result on the primary channel by the result on the
secondary channel.
Ratio can be measured between inputs A and B.
Back to the drawing board :-)
Dave
