Author Topic: tinysa ULTRA+ expert config  (Read 890 times)
Offline phenolTopic starter
« on: March 15, 2025, 08:48:57 am »
Has anyone gotten into the EXPERT CONFIG > INTERNALS menu yet? Looks like older models have mixer drive level options available there, but in ultra+ the menu is locked with a password.
Offline cte
Re: tinysa ULTRA+ expert config
« Reply #1 on: March 15, 2025, 05:59:07 pm »
try 5432
⚡ To avoid electric shock, ensure that your instrument is correctly grounded.
The following users thanked this post: DaneLaw
« Reply #2 on: March 15, 2025, 09:41:38 pm »
thanks, it works
Offline DaneLaw
« Reply #3 on: March 15, 2025, 11:13:48 pm »
A glance at some of the settings. (thx cte)
2523647-0
2523651-1
2523655-2
The following users thanked this post: cte
« Reply #4 on: March 16, 2025, 07:24:22 pm »
oddly enough,  nothing is selected in the mixer drive menu. 0-3dbm seems low for a level 13 mixer (ade-25mh)
Offline cte
« Reply #5 on: March 16, 2025, 10:17:20 pm »
By reading the source code... I think the value set in the mixer drive menu (0...3) is written to DB3/DB4 of register 4 of an Analog Devices ADF4351 chip. Seems like the labels in the menu are not correct. Datasheet shows -4dBm / -1dBm / +2dBm / +5dBm. (it's not my source code, so I might be totally wrong)
« Reply #6 on: March 17, 2025, 07:20:56 am »
I think the ultra+ model has a different synthesizer, a Maxim part. the Imsai guy did a teardown on YouTube
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7 on: March 17, 2025, 07:30:22 am »
@cte There is a password on the expert menu so you RTFM before using these features because there are serious caveats.
Online hugen
  • Country: cn
« Reply #8 on: April 03, 2025, 01:13:02 am »
Do not attempt to modify the mixer drive level of the ultra+. The ultra+ uses a higher gain and flatter LO amplifier than the ULTRA for higher frequency mixer drive, increasing the mixer drive level may saturate the LO amplifier producing a large amount of spurious signals.
Use the default AUTO option to ensure that the LO amplifier operates in the linear range and that the LO signal amplitude into the mixer is stabilized in the effective range of +10dBm to +14dBm.
