Author Topic: Tips and Tricks: R&S RTB2000/RTM3000/RTA4000  (Read 8059 times)
Offline Rich@RohdeScopesUSATopic starter
« on: July 22, 2019, 03:54:12 pm »
I thought I'd start a thread on tips and tricks for the RTB2000/RTM3000/RTA4000.  Some of these may be known already, but hopefully some are new.  I'll try to add more to this as I get time - feel free to add your tips/tricks too!   :-+
-Rich
Tap on clock opens time and date setup.
791844-0
Tap on interface icon opens interface short information window (e.g. this is helpful if you need the IP address quickly).
791859-1
Tap on gear wheel opens interface menu (this is more if you need to update your USB/Ethernet settings - it gives you quick access to that menu).
791853-2
Tap on information window opens numeric keypad.
791865-3
Tap on waveform marker to select a waveform.  Every marker is moveable.
791871-4
« Last Edit: July 22, 2019, 03:59:20 pm by Rich@RohdeScopesUSA »
The following users thanked this post: dr.diesel, egonotto, eetechTom, BU508A, hwj-d
Re: Tips and Tricks: R&S RTB2000/RTM3000/RTA4000
« Reply #1 on: July 22, 2019, 04:08:27 pm »
A couple more:
You can name your device:
 SCPI: syst:name “ViliWonka”
791877-0
If you tap on menu item it will increment the selection in pull down menu.
791883-1
-Rich
Online BU508A
« Reply #2 on: July 22, 2019, 04:29:31 pm »
Hello Rich,
thank you for this nice thread, saw two tricks which I didn't know yet.  :)
But may I ask you to increase the size of the screenshots? With some hi-res display they are a bit hard to read.
Thank you very much.
Mounty
Offline maginnovision
« Reply #3 on: July 22, 2019, 05:23:56 pm »
Hello Rich,
Mounty
Yea, here's what I get when I click the image. Without clicking it it's even smaller.
« Reply #4 on: July 22, 2019, 09:15:29 pm »
Sorry about that.  I'll make them larger.
-Rich
« Reply #5 on: July 22, 2019, 09:18:48 pm »
-Rich
« Last Edit: July 22, 2019, 09:25:49 pm by Rich@RohdeScopesUSA »
The following users thanked this post: eetechTom
« Reply #6 on: July 22, 2019, 09:26:07 pm »
Any better?
-Rich
Online BU508A
« Reply #7 on: July 22, 2019, 09:50:42 pm »
Yes.  :-+
Thank You Rich.
Offline hwj-d
  • save the children - chase the cabal
« Reply #8 on: July 23, 2019, 01:09:07 am »
Booked  :) :-+
« Reply #9 on: July 24, 2019, 03:22:26 am »
If you have several sources available, you can click on the measurement source icon to select another one:
-Rich
The following users thanked this post: maginnovision, bayjelly
Offline Harjit
« Reply #10 on: July 24, 2019, 03:43:24 am »
If the waveform tips are orange or you see up / down arrows next to the channel number on the bottom of the screen, that means the channel was clipped when it was digitized.
The following users thanked this post: Rich@RohdeScopesUSA, oh2hyt
« Reply #11 on: July 24, 2019, 07:28:01 pm »
This is one of my favorites for deep memory captures (works best with lots of memory turned on):
Set the waveform how you want to see it.  Adjust memory depth to an amount that gives offscreen data.
Press Stop.
Make a short swipe in the horizontal direction and the scope will automatically scroll through your waveform for you.
It can take a few tries to get proficient at it (if you don't get it right, the waveform will just move a small amount).  Sometimes helps to do it above/below the trigger level.
-Rich
« Reply #12 on: July 27, 2019, 03:41:51 pm »
If you connect a mouse (you can use a mouse and keyboard), you can use the scroll wheel on the mouse to emulate the "multi-purpose knob" on the front panel.
-Rich
The following users thanked this post: Warhawk
Offline Warhawk
    • Personal resume
« Reply #13 on: July 31, 2019, 01:13:56 pm »
Please, keep going with this thread.  :-+
« Reply #14 on: August 01, 2019, 05:54:11 pm »
You can tap on the calculated cursor value and it will open the cursor menu. If you tap on the automatic measurement value it will open the measurement menu.
-Rich
« Reply #15 on: August 09, 2019, 05:03:25 pm »
A couple cool Pattern Generator tips:
If you are in the arbitrary setup menu, you can tap on the signal it will change the bit level:
You can also tap on the value and manually enter what you want via the keypad and it will set the correct bit levels:
-Rich
« Reply #16 on: August 12, 2019, 02:11:26 am »
Turning on FFT and then pressing autoset will auto-configure the FFT's settings.
-Rich
« Reply #17 on: August 12, 2019, 10:28:09 pm »
You can set the waveform color (normal/rainbow/fire/temperature) via the channel menu:
-Rich
« Last Edit: August 14, 2019, 04:36:37 pm by Rich@RohdeScopesUSA »
« Reply #18 on: August 12, 2019, 10:39:42 pm »
Another one of my personal favorites - when you save a setup file, it also saves a screenshot.  You can then search by file view or list - in file view it will show you the screenshot.  I love this because I typically remember more what my setup *looked* like vs. what I named the setup.
-Rich
« Last Edit: August 14, 2019, 04:37:06 pm by Rich@RohdeScopesUSA »
The following users thanked this post: hwj-d, maginnovision
Offline hwj-d
« Reply #19 on: August 13, 2019, 10:18:54 pm »
The automatic picture rendering is faulty!
« Reply #20 on: August 13, 2019, 10:21:33 pm »
It looks OK to me.  Can you post a pic of what you're seeing?  I may be doing something wrong embedding the pics.
Thanks,
Rich
Offline hwj-d
« Reply #21 on: August 13, 2019, 10:32:29 pm »
Thanks,
Rich
That's not you. Something is wrong with the rendering algorithm.
The following users thanked this post: genghisnico13
Offline hwj-d
« Reply #22 on: August 13, 2019, 11:01:01 pm »
That must be serverside issue. Because this was FF Win10, but Safari iPadOS 13 is the same.
Depending on iPad orientation horizontal or vertical, there is more or less horizontal picture left on screen. The picture will not fit horizontal lower resolution client screens, as it is with picture expandable thumbnail method. If you have a bigger horizontal screenresolution, you din't notice the mismatch.
Offline hwj-d
« Reply #23 on: August 13, 2019, 11:07:26 pm »
Ok, that's OT here, should be reported to the admins.  :-BROKE
https://www.eevblog.com/forum/suggestions/there-is-another-issue-with-rendering-pictures-horizontal/msg2614179/#msg2614179
Edit: @Rich
I suggest to upload with "end of post expandable thumbnail" method. This pictures fits perfect.
Thanks
« Last Edit: August 13, 2019, 11:43:51 pm by hwj-d »
« Reply #24 on: August 14, 2019, 04:37:41 pm »
Edit: @Rich
Thanks
Thanks - updated.
-Rich
« Reply #25 on: August 15, 2019, 11:37:02 pm »
Another super cool one.  You can "pull out" menus so you have quick access to them.  Open the menu you want, grab it with your finger (or mouse) and slowly slide it to the left.  When you see the blue arrows you can pop it out in to the display.   You can then make quick changes.  You can also add multiple different quick access menus, move them around the display, etc. To delete them, just hit the gear and choose what ones you want to delete.
-Rich
« Last Edit: August 16, 2019, 04:31:02 pm by Rich@RohdeScopesUSA »
« Reply #26 on: August 15, 2019, 11:38:15 pm »
Does the gif above work for anyone?
-Rich
Online nctnico
« Reply #27 on: August 15, 2019, 11:39:12 pm »
Not for me.
The following users thanked this post: hwj-d, Rich@RohdeScopesUSA
Offline jjoonathan
« Reply #28 on: August 16, 2019, 12:30:14 am »
I couldn't get the forum upload for gifs to work either. Same symptoms. I've been uploading to gfycat.com and then hotlinking to the thumbnail from (User Heiroglyph > Profile). Presumably there's a bandwidth limit but I haven't hit it yet.
Offline EEVblog
« Reply #29 on: August 16, 2019, 02:16:02 am »
I'm guessing the new plugin doesn't support animated GIF's?  :-//
« Reply #30 on: August 16, 2019, 03:39:59 pm »
Thanks for the tip.  Hopefully what I did above works now (you have to click the image to see the animation).
-Rich
Offline Kean
    • Kean Electronics
« Reply #31 on: August 16, 2019, 03:59:54 pm »
Yup, thanks.  I'll have to try that - it looks really useful.
« Reply #32 on: August 16, 2019, 04:15:48 pm »
One more quick one - you can adjust window size easily using the arrows on the left side of the graticule.  This works in zoom mode, FFT, serial decode, etc.  No need to have a fixed window ratio.
Click on the image to see the animated version if the gif doesn't work for you.
-Rich
« Reply #33 on: August 16, 2019, 04:31:59 pm »
Looks like gifs are working again?   :-+
I've updated the posts - let me know if you all can't see them directly in the posts now.
-Rich
The following users thanked this post: Kean
Offline genghisnico13
  • Country: cl
« Reply #34 on: August 16, 2019, 05:09:32 pm »
The last one (the one about resizing) is perfect, good size and it works on desktop and mobile.
The one about quick access works, but is big on the desktop.
« Reply #35 on: August 16, 2019, 09:07:11 pm »
OneTouch is pretty cool too, especially if you're doing documentation.  Basically allows you to configure the "camera" button to not only save a screenshot, but also your setup, waveform file, references, event tables and even statistics, all in to a zip file on your thumbdrive with one push.  You can choose what all you want to be saved.
-Rich
PS - I tried resizing this one so hopefully it is more viewable across different platforms.  Let me know.
The following users thanked this post: Kean, hwj-d, maginnovision
Offline hwj-d
« Reply #36 on: August 16, 2019, 10:02:19 pm »
Horizontal resolution is fixed! This can't work.
(Think of smartphones.)
« Last Edit: August 16, 2019, 10:05:25 pm by hwj-d »
Offline zitoune
  • Country: sg
« Reply #37 on: August 02, 2020, 04:23:23 am »
Hi Rich,
Thank you for all those tricks; they are very useful!
I got a RTM for a couple of days now and love it. I was wondering how you can display the decoded values (say from an I2C bus) vertically - meaning the HEX values are not displayed like all the screenshots we usually see but rather like what's visible in that R&S image: https://cdn.rohde-schwarz.com/pws/powerslave/504580/18/import5a214aee0d0d9.jpg
Thanks!
« Last Edit: August 02, 2020, 06:41:25 am by zitoune »
Online Hydron
« Reply #38 on: August 02, 2020, 01:09:23 pm »
Use the V/div control to expand the decode vertically, then see if it'll do it.
The following users thanked this post: zitoune
Offline egonotto
« Reply #39 on: August 02, 2020, 02:02:24 pm »
Hello,
in the picture are not the decoded value in the table but the relative time of the single segments.
Best regards
egonotto
Offline zitoune
  • Country: sg
« Reply #40 on: August 02, 2020, 02:26:51 pm »
Thank you - indeed changing the V/div scale does work. Very handy, you can see more decoded values on the screen!
Offline zitoune
  • Country: sg
« Reply #41 on: August 02, 2020, 02:27:28 pm »
Hello,
Best regards
egonotto
Yes indeed, I was looking at the decoded values on the top part of the screen.
Offline egonotto
« Reply #42 on: August 02, 2020, 03:16:03 pm »
Hello,
what I can get is shown in the two pictures.
Best regards
egonotto
Offline zitoune
  • Country: sg
« Reply #43 on: August 20, 2020, 03:46:13 am »
Yes this is exactly what I was looking for and it is even more handy when decoding long words like in the attached screenshot (24bits I2S protocol).
Thanks.
