Author Topic: Symmetry issue with function gen EZ/Goldstar FG-8002  (Read 818 times)
Offline rodcastler
  • Country: cl
« on: February 26, 2018, 01:21:45 am »
My FG-8002 analog function gen (AKA GoldStar FG-8002) has a symmetry function that has the desired effect on symmetry however the knob also adjusts frequency, undesirably and quite substantially.
I would expect for the knob to adjust duty cycle, while keeping the previously set frequency steady.
I wonder if this is a design failure of this model or something broken that I should be able to fix.
« Last Edit: March 07, 2018, 11:36:18 am by rodcastler »
Offline rodcastler
  • Country: cl
Re: Symmetry issue with function gen EZ/Goldstar FG-8002
« Reply #1 on: February 28, 2018, 04:47:41 pm »
I found the attached schematic for this unit.
I suspect that something fishy could be going on with U5 or U4, where the two (freq and symmetry) appear to mix.
Any thoughts on where should I begin? and most importantly, do anybody else experience the same issue with this unit? Like I said, I'm not sure if it is working per design...
« Last Edit: March 14, 2018, 01:16:36 am by rodcastler »
