Author Topic: tla704 compact flash adapter  (Read 416 times)
Offline rommac100Topic starter
« on: May 03, 2022, 04:40:55 pm »
So I recently acquired a tla704 logic analyzer and have been gradually repairing it and upgrading. It is fully working at this point after doing a rtc battery mod but I would like to swap out the hard drives to compact flash as those drives should soon. Any suggestions for compact flash to ide adapters? As the star tech model that I got did not seem to work with analyzer at all. Would not post and would spit out beep codes (didn't get a chance to look into the beep codes).
Currently used compact flash adapter:
StarTech.com 40/44 Pin IDE to Compact Flash SSD Adapter - IDE to CF Card reader - CF to IDE Converter (IDE2CF),Black https://www.amazon.com/dp/B0026OYEEQ/ref=cm_sw_r_apan_i_VD58FBFAHKQ3YBDHXC32?_encoding=UTF8&psc=1
Currently used compact flash:
Verbatim 4GB CompactFlash Memory Card, 95188 Black https://www.amazon.com/dp/B0009X3MNU/ref=cm_sw_r_apan_i_G5MGGFMP4JN735112DQX?_encoding=UTF8&psc=1
