You zapped the meter with high voltage.Air ionizers (as used in electrostatic air filtration) generate voltages at several thousand volts (but almost no current) and "ozone generators" (very much discouraged because ozone is actually dangerous) produce even higher voltages.
Yes, well aware of the dangers of ozone. In my case it's just a small unit to add ozone to a aquarium.
Well took it apart and couldn't find any carbon traces or damage of the sort, not worth poking around. Time for another. Been awhile since I looked at budget DMM. Is the Uni-T 61E still a good buy or anything else new or on the horizon.
