Author Topic: Trigger Data hold on Philips Meters sans DataHold Probe?  (Read 1164 times)
Offline watchmakerTopic starter
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« on: August 19, 2024, 08:29:17 pm »
Is there a way to trigger DataHold on meters like the PM 2525 using the Din connector pins and a standard probe?
I have looked at various pinouts for this connector but they all address 4 wire resistance and temp probes.
TIA.
Dewey
Regards,
Dewey
Online abeyer
Re: Trigger Data hold on Philips Meters sans DataHold Probe?
« Reply #1 on: August 21, 2024, 01:42:28 am »
At least some of the models using that connector have service manuals with schematics available with the full connection details.
IIRC, pins 5-6 are an I2C bus and the data hold probe is active, sending messages on that bus which drive a bunch of relays controlling internal signal routing.
  • Self Study in EE
« Reply #2 on: August 21, 2024, 10:26:09 am »
Thank you.  I will look at the SMs of some of the other meters that use that probe.  I do have two other meters that hold (Flukes) and I would like to add this to the Philips.
Regards,
Dewey
Regards,
Dewey
