15V battery is also easy to DIY by using 2 GP23 12V remote batteries, and taking them apart to use the inside coin cells. Simply slide 9 of them into a small tight fitting paper sleeve, and put the end connectors from one of the donors on the ends, and roll the paper around then to stop them falling out. Then place in the space where the 15V battery went. If the new cell is a little short add an extra cell, as the voltage range will still work with 1V5 more without hassle, and will work longer as the batteries age.
