Arb encoder firmware first....
Now why did I think you had SDG2042X ?
I linked you the wrong firmware for SDG1032X that I saw in your video. Which have you got to put me outta misery wondering which ?
That's a SDG1032X. The second video shows the version number. Current at the time we purchased it. Still, I reprogrammed it for the peeps who felt the firmware would fix it.
Scopewise, I would be looking for something similar to my 15 year old Waveblunder 64Xi. I got it used in rough shape. I melted the cheap plastic case back together, LeCroy provided a new set of knobs that don't fall off every time it's used, it got an SSD upgrade (that the experts claimed would be problematic) and I straightened that cheap stamped metal case. Then there's the poor rework from the factory which was claimed to have been caused from the higher operating temperatures and poor mechanical design. It's PC based and has a coin cell battery buried deep inside. I've had to change it since I put it into service which is no fun. Best to keep your screw gun charged. It's easy enough to control over Ethernet but it's not very fast at moving data. Sadly they only support 100Mb and I can't drop in faster Ethernet card like I did with my fast scope. It throws off a lot of heat which isn't too bad in the winter but can be a problem in the summer.
The best part about this scope is how it recals. Use normal trigger, wait an hour for that signal you want to capture and what's it do? Recals. You turn off the auto cal and whats it do? Recals. I hate to say how many times I have lost the data I wanted to capture due to the recal.
It's not all doom and gloom. It's been my primary scope over the last several years. It has decent bandwidth, sample rates, memory depth and update rates. Screen size is also good. Brochure is here if you want to recommend something similar:
https://www.atecorp.com/atecorp/media/pdfs/data-sheets/lecroy-waverunner-xi_series_brochure.pdfAny idea what the Ethernet connection speeds are and sustained transfer rates are for higher end Siglents? Is there any benchmark data available?
