Another flea market find. More old tube military gear. Unfortunately the only manual I have with it is the one in the lid, which doesn't say what to do about the dreaded...hand interference. That is putting my hand near the machine to set the dial then moving it away, or even moving the headphone cable, causes it to become out of tune and start squealing. It only does with input enabled, it's stable on calibrating mode. It originally used batteries, but I found a disgusting trash parts power supply inside. Could that be causing the problem (HF line leakage)? If not what can I do to prevent this so I can actually use it?
