Author Topic: Siglent SSA3021X Relection Measurement Function "Problem"  (Read 1239 times)
Offline bte
  • Country: tr
Re: Siglent SSA3021X Relection Measurement Function "Problem"
« Reply #25 on: January 05, 2025, 07:50:57 am »
If I have to return it, I will then purchase a new SSA3021X directly from the Siglent website.
You could also buy it from Saelig, using the discount code you can get by posting in the https://www.eevblog.com/forum/testgear/equipment-discounts-from-saelig thread. I don't remember the exact amount of discount but maybe that could offset some of the price difference and allow you to get a Plus model rather than the regular model.
I am not affiliated with the company. I just read good things about them in the forum and wanted to remind about it as an option.
Offline tautech
« Reply #26 on: January 05, 2025, 08:34:12 am »
Thanks for the screenshots that clearly show the Reflection menus as not available.
I would suggest you install the older version firmware V2.1.1.4 but as yours is loaded with a version that is not publically available yet and has no promise there will be anything different, returning it is certainly an option to consider.
However knowing these analyzers as I do a good bit I would instead recommend the SSA3021X Plus, the updated version of SSA3021X.
The touch and mouse capabilities and inbuilt webserver are gained for not much more coin and totally worth it.
See reply #7 for the screenshot from SSA3021X Plus displaying the Reflection menu.
« Last Edit: January 05, 2025, 08:37:43 am by tautech »
