Hello,
I just got my hands on a Hantek DDS 3x25 arbitrary waveform generator. Unfortunately, I am seeing that when I plug the USB cable into the unit and it powers on, the AWG output swings to +3.5V for a short time, and briefly swings negative as well (to about -1.1V). You can see this in the attached image from a scope set up in persistence mode. Note that I am not using the auxiliary 5V DC input.
Anyone else seen this issue and/or have a fix?
Thanks!
