Thanks, the idea of the twisting, was to ensure the wire ends are physically together, because as you kindly describe, soldering them is a little difficult.
It seemed to work OK though....and if there was oxidation, then its not likely to be able to insulate the wires from each other significantly, since the wires are twisted tightly together anyway.
