Hi guys,
I have gen 1 uCurrent. Batterie is now at 2.951V (I was 3.12V, I just forgot it ON this evening
) I set switch to mA and I do measure the proper mA. I can easily compare it with my Fluke multimeter and I get same reading. I can only go down to 1mA with my fluke.
the project I am working on is nA.
So I set my switch to nA and it's only show 1.542V, I plug and remove LEDs and nothing change, I still read 1.542V I unplug the same components when testing in mA.
Now I remember the last time I used this (years ago) and that 1.5V does bring back memories.
I had a deadline for a digikey order so I quickly ordered u1 and u2. That did not solve the problem.
now I took the time to check the schematic.
I measure resistance of the
current input and I measure
mA = 0.3 Ohm
uA = 10.4 Ohm
nA = 9.99k Ohm
My fluke wire measure 0.2 Ohm
R1 = 0.2 Ohm
R2 = 10.00K Ohm
R8 = 10.5 Ohm
R6 = 99.9k Ohm
R7 = 99.7k Ohm
R3 = 75.1k Ohm
R11 =23.97k Ohm
I initially thought the Switch (SW1) was broken or something. I did not use this product a lot. But the fact that the
current input changes when I change the switch.
Kean mention to check virtual ground
https://www.eevblog.com/forum/testgear/ucurrent-blown-by-overcurrent/msg1776830/#msg1776830>>Also check the virtual ground (negative output jack) is at 1.5V with respect to the battery negative terminal (half battery voltage).1.435V
I am looking for suggestion, next time I will order the entire BOM
thanks
