Author Topic: Ultra Sigma Broken - DSA815  (Read 905 times)
Offline g0mgx
« on: February 02, 2020, 01:00:00 pm »
Hi Gang
I'm hoping there will be a whizzo on Ultra Sigma here able to offer me some help.
I have 3 Rigol devices (2 'scopes and 1 DSA815) - I can see and command the DSA815 from Ultra Sigma and the "Rmt" indicator comes on, but the screen printing to the PC fails with this error:
The two 'scopes work fine with this operation.
It was all working until I re-built the PC and hasn't worked since then..... so something is amiss but I am at a loss to see what.
Any input very much appreciated.
Mark
G0MGX
Offline PeDre
  • Country: at
    • Private Website
Re: Ultra Sigma Broken - DSA815
« Reply #1 on: February 02, 2020, 05:34:21 pm »
Did you install the IVI drivers? "DSA800 IVI Driver v1.0.4"
Is the picture format on the device not set to BMP? This may be causing the error. (System->Page 3)
Otherwise you can use my program "Rigol Bildschirmkopie" for screen copies. For the LAN connection you do not need to install anything.
[Link removed]
You might also be interested in this post:
https://www.eevblog.com/forum/testgear/spectrum-analyzer-rigol-dsa815/msg2890270/#msg2890270
Peter
« Last Edit: March 26, 2020, 07:44:26 am by PeDre »
The following users thanked this post: ted572
Offline g0mgx
« Reply #2 on: February 02, 2020, 07:54:44 pm »
Thank you, thank you, thank you!
  • The image type was set to PNG  |O
  • Your software is clearly excellent
Mark
G0MGX
The following users thanked this post: PeDre, egonotto, ted572
