Author Topic: Use of Oscilloscope Probe x100 Vs x1000  (Read 43941 times)
Online Phil1977
Re: Use of Oscilloscope Probe x100 Vs x1000
« Reply #25 on: April 06, 2024, 10:04:21 am »
Thanks for you replies. I have made quite experiments with oscilloscope but fortunately I hadn't blow up something yet and because I know all the danger with the grounding I ask to many things here. In same cases the the groung was not so clear how is arranged on the PCB I have used two identical probes and I 've done the differential math in the oscilloscope but I had noise on the measured signal because the ground clips are not connectioned. I have used differential probe but I would like to risk and measure with "ordinary" probes. Always there is something to new even with risk.
Okay, to learn abouts whats happening it absolutely makes sense to do the math in the scope. But if you (also) want to learn from other peoples experience, usually the quality of the results with a "analouge computer" in the probe circuitry is much better than whatever the scope can do digitally.
Personally I´d rather *only* use the differential probe, and if I want to measure against instrument ground I can also connect the "-"pole of the differential probe to instrument ground. It´s just THE big advantage of any differential probe, you can always select by yourself what part of the circuitry should be ground now. With the conventional probe you just don't have this choice.
Of course there are always many valid ways to many valid targets  :-//
The following users thanked this post: 2X
Offline 2XTopic starter
  • Country: gr
« Reply #26 on: April 06, 2024, 07:51:26 pm »
I have never used Testec probe or any other product of this brand... It has better, same or lower quality and safety from BK precision?
I have used many Testec probes and quite like them. Great quality at reasonable prices. The grips are a bit fatter than many probes, which I happen to like. I have some Testec at work and some at home.
Hameg (the test equipment company R&S purchased in order to break into the general test and measurement industry) shipped rebadged Testec with their scopes. (R&S now ships probes from another German manufacturer, PMK, which is more focused on high-bandwidth probes.)
Hameg oscilloscopes are very robust oscilloscopes... lifetime equpment.
