Author Topic: Uni-T launches the UT117C multimeter  (Read 24286 times)
Offline LeonRTopic starter
  • Country: br
  • PC hardware enthusiast
« on: June 26, 2023, 10:13:05 pm »
https://meters.uni-trend.com/product/ut117c/
https://www.aliexpress.com/item/1005005712613626.html
A bit more expensive their standard fare. Hopefully we'll get see PCB shots soon.
The following users thanked this post: Markus2801A
Offline Jon.C
  • Country: ad
Re: Uni-T launches the UT117C multimeter
« Reply #1 on: July 12, 2023, 07:03:06 am »
The following users thanked this post: Markus2801A, Serg65536
Offline slavoy
« Reply #2 on: July 12, 2023, 08:03:28 am »
At least they are trying to copy the good ones  8)
Online CosteC
« Reply #3 on: July 12, 2023, 09:59:24 am »
Strange instrument.
I like mechanical design and ergonomy seems good. Nice large display. Nice 3xAAA power. Seems robust too. BT is nice too. Hope filter functions will work well.
60000 display and 0.3% accuracy on DCV. What is the point? My old APPA 72 has 6000 display and 0.5% and last digit is meaningless anyway. UT117C has last two digits meaningless. Difference between 0.3% and 0.5% is negligible.
Current measurement is also weak - only 6.0000 and 10.000 ranges. Not great.
Wonder what will be the real price. Now it costs 130 euro/600 PLN - I think APPA/BRYMEN/SANWA are not far away.
Offline sonpul
  • Country: ua
« Reply #4 on: July 12, 2023, 03:06:28 pm »
This is more like an error in the technical specifications, the real accuracy is most likely 0.03%
I consider this particular model a real replacement for the 61E. Never liked the new 61E+.
The only thing that has not been done is a signal about incorrectly connected probes.
Online Aldo22
« Reply #5 on: July 12, 2023, 03:52:22 pm »
Yes, that sounds plausible when even a cheap AN870 has ±(0.05% + 3).
Then again, it's not a simple typo. Also the ACV is ±(1%+30) (AN870: ±(0.3% + 3))
« Last Edit: July 12, 2023, 06:15:38 pm by Aldo22 »
Offline ledtester
« Reply #6 on: July 12, 2023, 05:49:26 pm »
There are a couple of vendors selling it for $73 USD:
https://www.aliexpress.us/item/3256805457726202.html
https://www.aliexpress.us/item/3256805466430596.html
The following users thanked this post: gamalot
Online CosteC
« Reply #7 on: July 12, 2023, 07:48:13 pm »
Exactly. Datasheet is sensible for 0.3% DCV and 1% for ACV. It is "high resolution meter". Or maybe it has low drifts indeed and it is "high precision" in pure metrology sense  :-DD
Price is then for speed, robustness, good fuses, Bluetooth and useless decimal points on screen. Very probable CAT III 600V is fulfilled also.
Did anybody checked if AN870 has ±(0.05% + 3) after thermal cycling or bit less comfortable conditions than warm desktop? I do not doubt initial accuracy, yet for this price I doubt it lasts.
Offline sonpul
  • Country: ua
« Reply #8 on: July 12, 2023, 09:59:14 pm »
Still, I think that 0.3% is a mistake. Watch the video.
https://m.elecfans.com/v/384643/
Offline DaneLaw
« Reply #9 on: July 12, 2023, 10:30:16 pm »
Could be' as that certainly aint too shabby an accuracy, in regards to the 5080A cal ref.
Online Aldo22
« Reply #10 on: July 13, 2023, 08:49:56 am »
I don't know of any such test for the AN870, but there is a temperature stress test for the AN8008.
However, AN8008 only has a specified accuracy of ±(0.5% + 3) and the test (-20 and +60 °C) is well outside the specified temperature range.
So, that doesn't really answer your question.
Despite this, Joe Smith finds the results "pretty decent".
https://youtu.be/TSGLA9heboY?t=1593
Offline thm_w
  • Non-expert
« Reply #11 on: July 13, 2023, 11:11:00 pm »
Continuity test is odd, the screen shows continuity but it doesn't beep yet. Seems much slower than it could be?
Voltage range was fast and accurate, low resistance was slow to stabilize (~20s).
Offline kloetpatra
« Reply #12 on: July 17, 2023, 08:36:07 pm »
Received mine a few days ago. Continuity works without any flaws and is super fast. I like the meter in general. It's going to be my favorite one. Verified it against some Keithley 2000 with spot on measurements so far.
The following users thanked this post: thm_w, elantric
Offline sonpul
  • Country: ua
« Reply #13 on: July 18, 2023, 06:29:44 am »
kloetpatra, Please, do one test. What is the frequency range of TrueRMS? It is not specified anywhere in the characteristics of ACV Bandwidth. No one in the UT117C reviews measured the frequency range of AC V and AC mV. 1 kHz, 20 kHz, 50 kHz? Or maybe 100kHz?
Does the UT117C seem to have fast 5/Sec measurements?
« Last Edit: July 18, 2023, 09:33:46 am by sonpul »
Online Aldo22
« Reply #14 on: July 18, 2023, 11:49:16 am »
I didn't find this information either, but since the frequency measurement according to the specification only goes up to 9,999KHz, I wouldn't expect miracles (AN870: Frequency 9,999MHz!)
Offline kloetpatra
« Reply #15 on: July 19, 2023, 01:42:40 pm »
Yes, measurements update rate is 5 Hz. Bar graph update rate is 20 Hz.
BTW: User Manual (p. 20) says: AC * Frequency response: 45Hz~1000Hz
I did some frequency range tests: AC TRMS bandwith seems to be limited to 1 kHz for AC mV range and 10 kHz for AC V range. Still usable within 5% up to 1 MHz.
« Last Edit: July 19, 2023, 01:45:24 pm by kloetpatra »
The following users thanked this post: colorado.rob, sonpul, JoeRoy
Online CosteC
« Reply #16 on: July 19, 2023, 08:22:15 pm »
Can you test it on say, rectangular waveform instead of sine? 1 MHz is amazing, far beyond Keithley 2000, not mentioning UT117C!
Offline mwb1100
« Reply #17 on: July 19, 2023, 09:44:56 pm »
The posted test result at 1 MHz shows the Keithley 2000 slightly better than the UT117C: less than 2% low for the Keithley while the UT117C was 2.5% high.
The Keithley was far better at 1.5 MHz (5% low) than the UT117C (35% low).
Offline shakalnokturn
« Reply #18 on: July 20, 2023, 12:49:47 am »
Don't forget that this is a simple comparison of the readings of 2 multimeters, while the Keithley seems reputable enough and frequencies low enough (at the that point) to stick with kloetpatra's statement that the uni-pee is good up to 1kHz (mV) and 10kHz (V) (sine), we don't know enough about the test setup nor have a known reference to say that one meter or the other is reading high or low into the MHz...
Offline sonpul
  • Country: ua
« Reply #19 on: July 20, 2023, 04:20:27 am »
kloetpatra, Thank you very much for taking measurements and building such informative graphs. Very good work. Apparently, UT117C turned out great. If suddenly you have some other comparison results with keithley 2000, for example DCmV, DCV, R, etc. I will be very grateful for the opportunity to see them.
 Very good work. How do you create such charts?
Offline slavoy
« Reply #20 on: July 20, 2023, 05:22:07 pm »
Apologies for going off-topic...may I ask what software did you use to create these charts?
Offline BillyO
« Reply #21 on: July 20, 2023, 06:18:36 pm »
.3% on a 60000 count meter?  That's just silly.  +/-180 counts?  :palm:
I guess it's really just a 2.5 digit meter with cheap lipstick.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline alm
« Reply #22 on: July 20, 2023, 07:31:45 pm »
I guess the advertising about a high-precision meter, as opposed to a high-accuracy meter, is correct. Unlike Siglent with their 6.5 digit meters that drift due to lack of selection and burn-in of their references :-DD
Offline BillyO
« Reply #23 on: July 20, 2023, 07:40:53 pm »
Can't say much about the SDM3065X but I just checked and my SDM3055 has not drifted in 6 months.  Unless, of course, my calibrators have drifted by exactly the same amount as the meter on all the various ranges.  :-//
Offline ledtester
« Reply #24 on: July 21, 2023, 04:33:36 am »
Presumably the UT117C is designed to compete with the Fluke 117 and the spec sheet  for the Fluke:
https://dam-assets.fluke.com/s3fs-public/flk-2793260b-en-117-extended-specs-ds-w.pdf
states that it is only a 0.5%+2 count meter for DC accuracy so in that regard the Uni-T is better.
