Author Topic: What cheap EMC pre-complience eqipment to get for ~3500$  (Read 10176 times)
Online nctnico
Re: What cheap EMC pre-complience eqipment to get for ~3500$
« Reply #25 on: December 20, 2016, 05:24:03 pm »
It is not just an RF chamber. All tests require not only the right equipment but also the right setup (shielding, non conductive tables, etc, etc). If you want to make accurate measurements without a huge investment then there is no alternative than to rent a lab for a couple of hours.
I've never seen anyone rent out an RF chamber without the whole package or equipment and personnel needed for the standard suites of tests..
I wasn't writing about RF (emissions/immunity). EFT, Surge, ESD, conducted emissions all need very specific physical setups and these can also change when the requirements are updated.
Offline coppice
« Reply #26 on: December 20, 2016, 06:44:21 pm »
True, but the fact that these setups are so specific and well defined in standards means they are also trivial to reproduce. Very little thought is required. You just follow the formulae.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #27 on: December 20, 2016, 08:17:46 pm »
I would suppose, if you went to a testing lab and requested a custom quote for chamber time only, no support, you might get a good deal.  :-//  Or laughed off.  >:D
Low frequency (conducted) and transient stuff is easy enough to test with a ground plane.  You will easily see if there are nearby sources of interference (radio stations, maybe some particularly obnoxious power supplies?), which you'll have to subtract from your test.
Radiated can be done with an open-air test site, but you have to subtract even more ambient sources (potentially).  Or carefully select a site, and antenna direction (assuming you have sufficiently directional antennas), to get it quiet enough to actually perform the test.  And you need a good enough antenna / selection of antennas (I usually see conical dipole for 30-200MHz, log periodic for 200-1000MHz).  This definitely makes it more challenging to do radiated emissions outside of a test lab.  (And, not having a way to calibrate, say, 3 V/m emitted field intensity, and avoiding beaming that at just any radio user that happens to be nearby, is even more tricky!)
Seven Transistor Labs, LLC
Offline coppice
« Reply #28 on: December 20, 2016, 08:35:41 pm »
We used to do a lot of rough emission testing with the UUT on a table in the middle of a field, with pretty good results. Its RF susceptibility testing that is the biggest problem. Pumping out RF between 30MHz and 1GHz to achieve 30V/m or more at the UUT is going to annoy somebody unless you have a big field on the Montana scale of things.
