Author Topic: UNI-T UT372 tacho, works best off-angle ???  (Read 876 times)
Offline CirclotronTopic starter
« on: December 11, 2018, 01:14:55 pm »
Got one of these today:
https://www.ebay.com.au/itm/UNI-T-1-set-Red-Gray-UT372-Digital-Display-Speed-Tester-18-4-5-6-3-4CM-N1U9-/283142056140?nordt=true&orig_cvip=true&rt=nc&_trksid=p2047675.m43663.l10137
Didn't seem to work very well at all initially. Then I discovered that if you angled the beam 45 deg to the reflective surface it ran quite well. Question is - why wouldn't it work when the laser is pointing directly at (perpendicular to) the reflective surface? It showed a reading 20 or 30 times higher than actual rpm and very unsteady.
As far as accuracy is concerned it's pretty good. Connected a red LED to a function generator and aimed it at the receiver phototransistor. At 90,000 rpm equivalent (5-digit display) there was way less than 1 rpm error, judging by how long it spent on 90,000 vs 89,999.
« Last Edit: December 11, 2018, 10:13:47 pm by Circlotron »
