The UT61E does not have a back light, period. The only differences in versions is that the GS rated version has more input protection and lower CAT ratings.
I assume this would be what people refer to as the "European version" then.
Is this version only sold through European dealers (at increased cost) or can I just as well get it through eBay sellers etc. in China or wherever for a similarly low price as the other (non-European) UT61E version?
Obviously I'd look for a "GS" logo on the multimeter, but as photos and specs often don't match when you order through low-cost sources (eBay etc.) I would like to know before ordering instead of playing the lottery
UPDATE: It appears the GS approved (European) version is only available through European resellers and none of the low-cost sources from China, Hong Kong etc.
according to this posting:
I don't think Uni-T has any official distribution channel in the USA. What you get there basically directly comes from China. I think you are referring to the German/EU version with the upgraded fuses, which as far as I understand is only available in Europe. Chinese resellers do not seem to have access to these export-only products. I also don't think any Uni-T meters come with silicone test leads. The German version of the 61E does come with USB cable though (instead of RS232 in the Chinese version).
I'll be using mine mostly for low-voltage DIY projects and occasionaly measuring AC 230V household current -so will the "Chinese" version suffice, or is the GS approved version much safer and better built in general?
Backlight would be nice, and I've read about the modifications which disables the Peak Hold function, using it for the backlight instead, so I'm not very interested in that and guess I can live without a backlight.
The UT139A seems similar to the UT61D, but apparently at a lower cost. Got to look deeper into the specs for that one, but the Hz range of the UT61E is what appeals to me.
