Author Topic: UNI-T UT61E Digital Multimeter Continuity Test Not Working  (Read 595 times)
Offline fabry891Topic starter
« on: December 26, 2024, 05:15:01 pm »
Hello everyone,
I have had a UNI-T UT61E digital multimeter for a few years now, which has always worked well for my hobby use.
Today I noticed that in continuity test mode if I put the two leads in contact, even with a low ohm value less than 1, I do not hear the beep, but I hear a quick beep only when I disconnect the leads. Also in DC voltage test mode, even without leads inserted, I have a value of about -0.3 V.
I also tried to power it with an external power supply, to exclude the battery problem, but the problem persists.
I wonder if anyone has already had the same problem as me and how to solve it.
Thanks.
Online Kleinstein
Re: UNI-T UT61E Digital Multimeter Continuity Test Not Working
« Reply #1 on: December 26, 2024, 05:51:31 pm »
Using an external power supply is usually a bad idea.
Geting -0.3 V DC when open is a bad sign and likely not directly related to the continuity problem.
With a handheld DMM there is usually is low chance for a repair, as parts are hard to get and new calibration may be needed, that may be difficult (rarely the procedures are public) or expensive to get.
A possibly issue effecting multiple areas could be a damage from humidy or a leaking battery. If no longer under warranty, maybe have a look.
The following users thanked this post: fabry891
Offline Fungus
« Reply #2 on: December 26, 2024, 06:45:47 pm »
That sounds bad.
What was the previous thing you did to it?
Online mendip_discovery
« Reply #3 on: December 26, 2024, 07:22:57 pm »
Check your test leads/try another set.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline Fungus
« Reply #4 on: December 27, 2024, 05:34:28 am »
Bad leads won't subtract 0.3V DC from the input, especially when they aren't connected.
« Reply #5 on: December 27, 2024, 02:27:58 pm »
That sounds bad.
Nothing special, I always work with low voltage and low current. I don't know if it's my fault or the quality of the instrument.
« Reply #6 on: December 27, 2024, 02:31:57 pm »
Tried another set of leads, same problem. Same leads on another meter work. Mystery. I think I'll just keep it that way at this point. Eventually I have another multimeter/oscilloscope for more precise measurements.
Online tunk
  • Country: no
« Reply #7 on: December 27, 2024, 03:48:11 pm »
Take it apart and clean the rotary contacts?
Offline Fungus
« Reply #8 on: December 27, 2024, 03:50:40 pm »
Turn the switch vigorously a dozen times. Push down on it, hard.
Offline stj
« Reply #9 on: December 27, 2024, 05:42:34 pm »
post a pcb picture.
there are 2 variants - if i see which you have i can post a schematic.
it could be as simple as a shorted diode.
« Reply #10 on: December 27, 2024, 10:42:30 pm »
post a pcb picture.
Following some forums I tried to remove the potentiometer VR1 (2k ohm, while in the circuit diagram it is indicated 1k ohm) and the DC value returned to almost zero, but obviously not from correct voltage readings, while always without the potentiometer, the continuity test works correctly. Does this mean something?
Here are the pictures of the pcb.
https://photos.app.goo.gl/QZ5J3MTrFgMMEqaJ6
https://photos.app.goo.gl/HgmjpTX6Ghv68PAh7
Circuit diagram:
https://photos.app.goo.gl/VvY5VaPfyc5fJD6C8
Offline Datman
« Reply #11 on: December 28, 2024, 02:48:40 pm »
- Measure VR1
- Verify that the value is less than the total resistance
- Take note of the value
- Move a bit the cursor
- Verify a minimal resistance variation
- Move the cursor some times
- Replace the cursor at the previous resistace
- Reinstall VR1.
