Would be nice if somebody who owns two UT61E with USB interfaces could make a test
-Didix
Basic test with 2 UT71E: Works.
After startup of each instance, you can select between USB1 and USB2, and then display the data from the meter.
From the window you can select "Log to file" and then define a log file name for each window.
Trap for young players: Don't forget to activate "Send" on the UTs. Otherwise you might curse and search for a minute or so
Nice tool. Not beautiful, but it does its job.
btw: Tried the same with the UNI-T software v3.00, but with the original USB ports of my laptop:
Actually it works with two instances, but if you open the second window, both will log data from the same unit
Apparently, it's not intended to be used with identical meters...
