Author Topic: UNI-T UT61E Multimeter teardown photos.  (Read 726148 times)
Offline PedroDaGr8
  • A sociable geek chemist
Re: UNI-T UT61E Multimeter teardown photos.
« Reply #650 on: August 15, 2013, 03:26:46 pm »
Close, the "new" scope is the apparently quieter LeCroy 9410 with all options (including FFT). This one isn't that loud at all, more of a gentle purr. I picked it up locally for $120 with two tek 10x probes thrown in for free.
Sent from my EVO using Tapatalk 4
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline notzippy
« Reply #651 on: August 20, 2013, 08:22:22 pm »
Noticed on the website the UT61E is supposed to have a backlight http://www.uni-trend.com/UT61E.html , although the manual indicates otherwise. anyone know what is correct ? Looking at the first post it appears there is no backlight, but things can change..
thx
Nz
Offline Lightages
  • Canadian po
« Reply #652 on: August 20, 2013, 08:55:26 pm »
The UT61E does not have a back light.
Online mariush
« Reply #653 on: August 20, 2013, 08:57:20 pm »
It also says sleep mode 15 minutes while there's no such mode.
No, imho, it's just bad data. The english version of the site is not really updated, check the chinese version always:
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.uni-trend.com.cn%2Fcp-show.asp%3Fyy%3D%25D6%25D0%25CE%25C4%26ProductNO%3D481&act=url
(^^Google Translate above) No backlight and sleep here.
Offline Electro Fan
« Reply #654 on: August 20, 2013, 09:31:26 pm »
...Plus more multimeters is always priceless and enables to do alot more things....Unless they come out with a multimeter with multiple isolated channels, those things are hard to beat when combined.
I am reasonably happy with the 61E.  I already have 3 others - 2 radioshack and a DT830B.  But I actually was thinking about getting a couple more  DT830B's when I was playing around with boost circuits:
In Volt, in current, out Volt, out current, drain current, that is 4 right there.  I could use another one to do adhoc readings.
One of my 4 is a DT830B, $6 DMM, not bad.  I use it as my volt meter for my PSU.  It actually performs better than the other cheapos from Radio Shack (4-8 years old).  So I was considering getting a pair of DT830B.  But I hate all those stuff on my table leaving me so little space.
I would not invest in another mid-low end DMMs.  If I would get more DMMs, I will probably aim for a higher end ones or real cheapies.  Mean time, I just got my ATMega328 as Volt/Current meter working on a breadboard and ordered parts to transfer it to PCB.  I divided up the 6 ADC's as 3 pairs of volt+current (switch-selectable) 0 - 5/15/30Volt and fixed 0-4Amp (using a 0.1ohm as current sense and amplified with OpAmp).  The two pairs I have working gets me +-1% to 4% accuracy.  Not bad when I have not yet calibrated them yet.  After I get the parts, I can get the 3rd pair working, transfer it to PCB, and then I'll do some software tricks (the ADC under-reads at low ranges).  If I can bring it closer to 1-2% using my UT61E as "accurate" reference, I just may end up using the ATMega as my PSU's volt+current.  All three channels shares common ground, so it took me a while to figure out how I would make that work for me.  If the thing works (at +- 1-2%), I don't need the DT830B's as volt/current meter.  If it doesn't, well, I learned a lot trying to get it working so far.
Please keep us posted on how your Atmega328 meter reading project is going - I'm sure some folks would be up for trying your design if you want to share it.  Thx
Offline notzippy
« Reply #655 on: August 20, 2013, 09:34:44 pm »
Thanks, the picture on their site certainly looks like its backlight. Although your right about the specs stating "background light" is definitely not checked. Not really a deal breaker for me, just trying to get the best bang for the buck these days..
Nz
Offline Rick Law
« Reply #656 on: August 21, 2013, 03:53:50 am »
Sure, I will share what I learn.  I am learning some interesting stuff at least for me the newbie.
I am working on it on my spare time, so it will take at least another one or two months.
Offline george graves
« Reply #657 on: August 21, 2013, 04:24:26 am »
I was planning on adding one - but the display is so sharp and clear, that you can see it in even the dimmest of rooms.  It's better then a fluke 87-5.
Offline algorath
  • Country: at
« Reply #658 on: October 08, 2013, 03:03:41 pm »
i recently had to open mine up for repair. the A range was somehow shorted with the Hz, or Ohms i dont remember. turns out there was some sort of debree (im guessing from the pcb) that got stuck on the range switch. also one of the range springs was kinda corroded  :--
Offline form
« Reply #659 on: October 08, 2013, 05:58:34 pm »
Has anybody seen software-bugs on that DMM, too?
Sometimes the autoranging fails and instead of changing the range, the displayed value is just wrong.
Very dangerous...
Offline Monkeh
« Reply #660 on: October 08, 2013, 06:03:21 pm »
It has no software.
Very dangerous...
I have yet to have this occur.
Online mariush
« Reply #661 on: October 08, 2013, 09:41:08 pm »
It has no software.
Very dangerous...
The update rate is 2 times per second on the UT61E.
When changing ranges, it happens that one update is messed up (sometimes it just moves the dot instead of dropping a decimal, for example when going from 22.124v to 25.12v, you get 251.24 or something like that). But this is basically shown for half a second (one update) with the next update half a second later, the correct value is shown.
Once you get used to it, it's not dangerous at all and these erroneous values can be easily scrubbed out of log file, if you do data logging.
Offline Monkeh
« Reply #662 on: October 08, 2013, 09:45:04 pm »
It has no software.
Very dangerous...
I'm well aware of that particular issue, that is not what he described.
Offline safetyfirst
« Reply #663 on: October 09, 2013, 03:28:37 am »
See page 41 of the Uni-T Series 61x Operating Manual.  The 61E does NOT have a Backlight or a Sleep mode / Auto Power Off (APO).  I cannot post the entire manual as the pdf is almost 5MB.
Offline Lightages
  • Canadian po
« Reply #664 on: October 09, 2013, 03:32:50 am »
The UT61E is a nice meter for the price, but don't expect too much out of it. For a 22,000 count meter with many good features it is a good buy. Keep it on the bench and don't even show anything high energy or high voltage. If you want something safer, then you have to do with lower specs or higher price to keep the same specs.
Offline Wytnucls
« Reply #665 on: October 09, 2013, 04:06:12 am »
Very dangerous...
Nobody else has ever experienced anything like that. There could be a fault with your meter. Did you capture it on video?
Offline algorath
  • Country: at
« Reply #666 on: October 09, 2013, 06:49:43 pm »
the lack of backlight and auto power off are really strange. what´s that cost, 1$? personally i don´t miss a backlight too much. but i´ve had my batterie drained a couple of times cause i left the damn thing on for 2 days straight :) good thing i got recharchable 9vs
btw, there´s an easy tutorial on yt on how to add backlight
Offline user4963
« Reply #667 on: October 15, 2013, 01:24:35 pm »
Hi .
Please help me. I dont know. it: C11b*,C11a*,C10a*,C9a*,C9b*,C8a*,C8b*      :wtf:             ?
and If the circuit diagram of this model. Do you know download on
Offline PedroDaGr8
Re: Re: UNI-T UT61E Multimeter teardown photos.
« Reply #668 on: October 15, 2013, 03:20:25 pm »
Hi .
If I remember correctly it appears the * means alternate locations. I don't know if they are there to allow them to source cheaper parts or what but often they are not populated.
Sent from my EVO 4G LTE using Tapatalk
Offline Lightages
  • Canadian po
« Reply #669 on: October 15, 2013, 04:24:04 pm »
I would guess that they are values that are subject to change or adjustment for trimming accuracy. Here is the schematic.
Offline user4963
« Reply #670 on: October 15, 2013, 05:41:19 pm »
That not schematic. ?t ic 1778 ? and How do I find the values ??of these elements.
Multimeter shows wrong value. 1K play in resistance measurement.
Please somebody help me. How do find ic 1778 schematic ( or ic 1778 datasheet )
Offline Lightages
  • Canadian po
« Reply #671 on: October 15, 2013, 05:48:43 pm »
That is the schematic. I don't know what you are asking.
Offline Legit-Design
« Reply #672 on: October 15, 2013, 06:08:48 pm »
To my knowledge "ic 1778", that black thing next to those smd capacitors, is precision hybrid resistor network or similar. Please take  picture of the resistor you are measuring and how you are measuring it. I think the problem might lie in your measurements also. If you measure 5% resistor, its value might be +-5% of what is actually says on the resistor. Also don't measure resistors directly in circuit it might cause faulty readings. Since there is a language barrier taking pictures might be easiest thing to do.
Offline user4963
« Reply #673 on: October 15, 2013, 06:10:14 pm »
The diagram C11a*,C11b*,.... no.I'm looking for these values
Offline user4963
« Reply #674 on: October 15, 2013, 06:29:11 pm »
Thank you
10k resistor.. Multimeter 9.205 measure vicinity
