after my last impulse purchase of a crap DMM (
see here, the "killer") this time I intentionally searched for a bizarre device. I tried to find the most ridicilous DMM possible (right before the level of the bluetooth speaker dmm). Like the "best" manual ranging chinese miracle device possible.
I found it and I purchased it. After my last good experience with UNI-T (3 years ago, had a rebranded UT insulation tester that burned down at normal usage) I decided to give them another chance.
The UNI-T UT89XE. 20.000 Counts of manual ranging ridicilousness. This toy cost me 46€. Yes, no transistor testing included, and yes, it contains fuses, but I had to go for it anyways.
Automatic backlight, peak, min/max, continuity with led indication, diode with "beep"-indication, conductivity measurement, frequency, capacity, current, voltage (truerms), resistance, temperature... Mold-on soft case. Autoranging on capacity and frequency. Fuse access without opening the case. Crappy test lead jacks. What a marble. Claimed DC accuracy 0.05%+5, comes with Type K probe, standard Unit-T test leads. Rest can be found at the
UT89XE Product page and the
user manual.
And yes, I will now stop buying those chinese toy meters. That's it. :-)
It has some alibi input protection with 250V fuses and a couple of small PTCs and even some clamping. I wouldn't trust the rating. Looks like bare minimum, but ok for non-mains voltage low energy elv hobby usage.
DMM-Chipset is Cyrustek ES289B, some sensitive components are even under a big metal shield. It has a trimmer for manual adjustment :-)
And it's manual ranging! MANUAL! Like in the old days! But with 20.000 counts! I already feel like over 9000% more competent when I have to cycle on millions of options and ranges. What a great toy.
Anyways, I did some quick comparisons on the desk to my BM789:
At ~23°C against my reference:
2.5V: 2.498V (BM789: 2.4982V)
5.0V: 5.000V (BM789: 5.0004V)
7.5V: 7.499V (BM789: 7.499V)
10V: 10.001V (BM789: 10.001V)
100R: 99.74 (BM789: 99.96)
1k: 0.9987k (BM789: 1.003k)
10k: 10.000k (BM789: 9.997k)
100k: 100.02k (BM789: 100.02k)
At ~230V 50Hz mains voltage it deviates about ~1V from the BM789 and beeps regularly.
Temperature measurement looks mostly comparable to what the BM789 reports for room temperature and when putting them both next to the open window. I took some electrolytic from the box, labeled with 2.2mF, the UT89XE measures 2.074mF in about 4s (BM789: 2.15mF).
Some nearby diode gave a reading of 491mV (BM789: 465.3mV). Diode testing gives 2.9V output voltage and lights up some LEDs I had around.
Continuity test is very quick, latched and gives red LED feedback on continuity.
Display is nice, viewing angle is ok, bit bad from the very top, backlight works well. Switches on automatically when it's dark and goes off after some timeout if it's light enough again. Auto power off of the device worked.
Crazy toy.
Best regards,
Martin
