Author Topic: UNI-T UTG962E sig gen. Rasping noise at switch on  (Read 2589 times)
Offline 807Topic starter
« on: January 29, 2023, 04:17:58 pm »
* Sig gen noise.mp3 (126.73 kB - downloaded 70 times.)Does anyone else get a rasping noise when switching on their UTG962E? It doesn't do it every time, but around 50% of the time it does. I haven't opened it up, so don't know if it's coming from the piezo buzzer or the relays.
I've attached an audio file.
Sometimes it goes on for longer & sometimes just a few clicks.
« Last Edit: January 29, 2023, 04:20:59 pm by 807 »
Offline BillyO
Re: UNI-T UTG962E sig gen. Rasping noise at switch on
« Reply #1 on: January 29, 2023, 05:34:05 pm »
Yikes!  :scared:
That sound is not supposed to come from any sort of electronic device.
I would open it up just to see where the noise is coming from.  Don't worry about your warranty.  Since it's a UNI-T you don't really have a warranty.
Offline coromonadalix
« Reply #2 on: January 29, 2023, 05:54:38 pm »
someking of hissing noise ??   psu section, anything  like switching frequency at startup ??
« Reply #3 on: January 30, 2023, 10:05:30 pm »
Yikes!  :scared:
yep. I will open it & try & find where the noise is coming from. Although I'm not sure if I will still be able to fault find it, as the most it goes on for is around 2 seconds. And it doesn't do it every time.  >:(
I was just wondering if anyone else has the same problem. I've seen a few reviews & no one else has mentioned it.  :-//
« Reply #4 on: January 30, 2023, 10:12:27 pm »
It's not a hissing noise, it's a rasping'farting kind of sound that gradually decreases in frequency.
The sig gen uses a seperate power supply that has a USB socket. The cable supplied is a USB to barrel lead.
I suppose it could be the PSU. I could try a different power supply for a few days to see how it goes.
