Products => Test Equipment => Topic started by: 3nigm4 on December 19, 2016, 02:13:15 pm
Title: Uni Trend UT71D v12 pictures
Post by: 3nigm4 on December 19, 2016, 02:13:15 pm
Today the bought UT71D has arived and just the time to test it if power up, and a little teardown to see its iterior.
Here are some pictures but seems about the same as previous: glass fuses (enough for my usage)
The PCB is marked V20051010-12 71A
Title: Re: Uni Trend UT71D v12 pictures
Post by: Mitsch on December 28, 2016, 09:44:25 pm
Mine is from 12/2014 and has no glass fuses.. Very odd...
https://www.eevblog.com/forum/reviews/uni-t-multimeter-ut71d-unboxing-and-teardown/msg605921/#msg605921 (https://www.eevblog.com/forum/reviews/uni-t-multimeter-ut71d-unboxing-and-teardown/msg605921/#msg605921)
Post by: mzacharias on December 28, 2016, 10:45:10 pm
As I understand it, Uni-T only supplies the better fuses to those destination countries which require them by regulation.
Post by: 3nigm4 on December 29, 2016, 11:04:48 am
Yes, that is odd... from all the versions around, buying an Uni-T remembers me Forrest Gump's sentence: is "like a box of chocolates. You never know what you're gonna get"
Post by: Hydrawerk on December 31, 2016, 01:17:52 am
A very poor input protection.
Post by: 3nigm4 on December 31, 2016, 04:44:58 pm
Other info to add:
- looking at the schema of the meter, the Voltage Reference IC is hooked to the second TI IC under the display and comunicate only to the MCU: that seams that the value compensation is made digitally by the MCU, and not by the ES51966 where its VRef is composed by resistors+cacitors+trimpot;
- the True RMS IC used is an AD636/ES636 that specifies that the accuracy is granted to 1kHz: higher frequencies compromise the accuracy; the IC is the same in many other meters where the accuracy for TRMS is granted to 1KHz... so there's no difference between UT71x and others 1kHz, even if Uni-T is reporting 100kHz bandwidth
Post by: sync on December 31, 2016, 05:33:59 pm
The specs for the UT71[cde] above 1kHz are bad.
1-10kHz: 3% + 30 counts
10-100kHz: 6% + 30 counts
I did an AC voltage frequency response test for a few DMMs. Including my UT-71C. I used an old Russian B1-9 AC calibrator as source. I did only test with 1Vrms (sine wave).
freq   K2000     34401A    UT-71C   UT-61E
  20   0.99963   0.99949   0.9877   0.9936
  50   0.99990   0.99973   0.9961   1.0001
 100   0.99997   0.99980   0.9975   1.0018
 200   1.00003   0.99991   0.9978   1.0028
 500   1.00003   1.00001   0.9982   1.0033
  1k   1.00006   1.00004   1.0003   1.0030
  2k   1.00006   1.00006   1.0043   1.0020
  5k   1.00009   1.00010   1.0089   1.0001
 10k   1.00010   1.00014   0.9962   1.0010
 20k   1.00017   1.00019   0.9811   1.0083
 50k   1.00015   1.00003   0.9826   1.0575
100k   0.99993   0.99964   0.9913   1.2083
Post by: joeqsmith on December 31, 2016, 05:45:47 pm
I can believe the UT61E peaking to 1.2 at 100K.  I had ran a 1 volt AC sweep of the last 61E I bought before I started to modify it (top graph).  It peaked at 150KHz.
