the fluke and the racall are whole different meters then the 5335.
the hp has multiply, add, substract, divide and a few more things.
this is handy when working with IF or with my /8 and /64 prescalers to 12ghz
Its a well respected counter, but IMHO the Racal Dana 199x series are better; less reports of them not working, run near $100, and the key complaint is the keyboard which is easy to repair. More unobtanium in the HP5335a. You can find discussions on the Racal in the archives.
Having HP5334A, no Fan anywhere. Must be the 5335 Series. ^-^
Received now my Jupiter-T GPS receiver...also an external antenna....
From the description I read that the GPS module features an SMA connector...but seems it must be something else as the GPS antenna with SMA doesn't fit....
Someone knows what kind of connector the Jupiter-T Navman module has in the picture?
Looks to me like a SMB connector.....
echo -ne '@@Ea\x01\x25\x0D\x0A' > /dev/ttyUSB0
