Author Topic: Unknown mechanical (measurement?) device identification  (Read 1516 times)
Online daqq
  • Country: sk
    • My site
« on: December 29, 2016, 08:07:57 am »
Hi guys,
This device was posted on a local trading site. I have no idea what it is, nor does the seller, he only listed it as "Measurement device". Any clue? I'm not planing to buy it, it only seemed interesting. There are no markings readable aside from:
Vz. 34
tov. cis. 2510
cis. 645
. The 'Vz. 34' is probably "Vzor 34" which would indicate a type, but nothing turns up when this is searched. The 'tov. cis. 2510' is a factory internal number probably and the 'cis. 645' might be a serial number?
Any ideas as to the function?
Thanks,
Re: Unknown mechanical (measurement?) device identification
« Reply #1 on: December 29, 2016, 08:16:20 am »
I'd say it was a precision Inclinometer, for measuring the slope of a plane in degrees from level.
This pic clearly shows both graduations and what appears to be a Vernier scale to take readings to a fine tolerance.
Edit
Definitely worth grabbing if it's cheap to ensure you're still on the level. <wink>
« Last Edit: December 29, 2016, 08:25:00 am by tautech »
Avid Rabid Hobbyist
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: December 29, 2016, 08:24:46 am »
Looks a bit like these indeed.
https://www.leveldevelopments.com/products/inclinometers/mechanical-inclinometers/83m-mechanical-inclinometer-range-360-degress-accuracy-1-5-magnetic-base/
It's not my field at all, but I think you turn the wheel on top until the bubble is centered, then you can read the angle.
But how this works with accuracy in minutes, I don't know.
« Last Edit: December 29, 2016, 08:27:47 am by Jeroen3 »
Online ataradov
    • Personal site
« Reply #3 on: December 29, 2016, 08:24:54 am »
Well, LT vz. 34 is a tank, so this may be some sort of aiming implement. In which case, it would be a very interesting buy. How much is it?
PS: A tank made in Czechoslovakia, so even geographical location is close.
« Last Edit: December 29, 2016, 08:28:36 am by ataradov »
Alex
Online daqq
  • Country: sk
    • My site
« Reply #4 on: December 29, 2016, 03:48:28 pm »
Thanks guys, that seems to be it.
