Author Topic: Unlocking DS1074Z S-PLUS  (Read 7420 times)
Offline zanzeoo
« on: January 08, 2016, 05:56:50 am »
Hi every ! I've just bougnt the new RIGOL DS1074Z S PLUS , I tried the unlock keygen tool but none keys seem to work
Software version is 00.04.03.SP1
Board 6.1.1
Does anyone can help me ?
thx !
« Last Edit: January 08, 2016, 06:32:47 am by zanzeoo »
Offline TheSteve
  • Living the Dream
Re: Unlocking DS1074Z S-PLUS
« Reply #1 on: January 08, 2016, 06:38:12 am »
I highly doubt the new Plus models are supported by any key gen(but hope I am wrong).
VE7FM
Offline zanzeoo
« Reply #2 on: January 09, 2016, 08:06:50 am »
me too ....
Offline Howardlong
« Reply #3 on: January 09, 2016, 08:33:11 am »
Are these not MSO upgradeable? In which case, maybe the MSO1000Z procedure is needed.
Offline TheSteve
  • Living the Dream
« Reply #4 on: January 09, 2016, 08:50:45 am »
I think you might be on to something.
zanzeoo check out this thread:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg569236/#msg569236
VE7FM
Offline Spiral
« Reply #5 on: February 20, 2016, 04:59:40 pm »
Any luck with this one?
Offline Spiral
« Reply #6 on: February 22, 2016, 05:44:54 pm »
I completed the procedure outlined in that thread on my DS1074Z-S Plus and can confirm it works.
Offline Gioreva
« Reply #7 on: March 09, 2017, 12:39:45 pm »
Logic probe are passive wire?
Can I make it myself an unlock logic analyzer?
Offline Howardlong
« Reply #8 on: March 09, 2017, 05:20:21 pm »
Offline Gioreva
« Reply #9 on: March 10, 2017, 11:48:31 am »
Ok
But without the logic probe, does it work?
Connecting the wires to the connector directly?
Those comparators increase the efficiency, but for most applications, slower, could fit the same.
It 'a commercially available connector?
Offline Howardlong
« Reply #10 on: March 10, 2017, 03:45:41 pm »
Ok
It's a high density connector, without measuring it I'd say 0.05" pitch. This is because the signals between the pod comparators and the scope are differential, so you'd need to deal with that aspect as well as any amplitude and CM adjustment.
I am sure you could cobble something together, whether you'd want to though is another matter!
Offline zanzeoo
« Reply #11 on: September 19, 2018, 06:58:17 am »
Hi
Thx you but i think the link is dead... :(
Offline RoGeorge
« Reply #12 on: September 19, 2018, 07:25:37 am »
The link doesn't work because of the apostrophe character in the URL.
Replace it with an underscore: https://www.eevblog.com/forum/testgear/sniffing-the-rigol_s-internal-i2c-bus/msg569236/#msg569236
(note the link is spelled now with "rigol_s" instead of "rigol's")
