Author Topic: Unlocking late unit SDG2042X  (Read 1858 times)
Offline klossTopic starter
« on: January 15, 2023, 11:18:24 am »
Is it possible to unlock a late manufacture SDG2042X to extend the frequency range upwards? I went through the previous threads I could find on this topic but although I am able to login to the SCPI Instrument screen via Putty, entering the commands does not result in being able to view or edit any data, no data appears on the screen to be able to scroll down to using the arrow. I also found that it is not possible to roll back the firmware to versions 15R2 or 16R2, only as far back as 17R5. Having said that, i'm apparently able to login via Putty using any of the later firmware files including 37R3. It simply doesn't respond with any data to edit. Screen print attached.
Re: Unlocking late unit SDG2042X
« Reply #1 on: January 15, 2023, 11:42:52 am »
Oh really, just download the programming guide:
https://int.siglent.com/u_file/download/22_08_26/SDG_Programming%20Guide_PG02-E05A.pdf
P12 gives you all you need.  ;)
« Reply #2 on: January 15, 2023, 12:10:17 pm »
Thanks, but same problem  :-\
Offline tv84
  • Country: pt
« Reply #3 on: January 15, 2023, 12:30:36 pm »
In a SCPI "shell" like you have you can ONLY issue SCPI commands.
That's not a linux shell!
« Reply #4 on: January 15, 2023, 01:05:05 pm »
Thanks, so I need to be using a linux shell. Any suggestions for running one under Win 7? Or am I looking at a Linux PC/lappy to run it.
« Reply #5 on: January 15, 2023, 01:36:46 pm »
I just tried Cygwin (inetutils version) but no joy so far
Offline Martin72
  • Testfield Technician
« Reply #6 on: January 15, 2023, 03:50:22 pm »
« Reply #7 on: January 15, 2023, 04:08:19 pm »
Thanks. I think that is for the SDS2000X scope? I have the SDG2000X Gen
Offline Martin72
« Reply #8 on: January 15, 2023, 04:45:31 pm »
I know...
Look again at my post there, I´ve upgraded my SDG2042X, not a scope.
« Reply #9 on: January 15, 2023, 07:23:34 pm »
Thanks, i'm not sure I follow that approach or can see where the script used is, but I will keep it in mind for an attempt if the method i'm trying fails.
Offline Martin72
« Reply #10 on: January 15, 2023, 07:27:27 pm »
It´s so easy that even I could do it...
« Reply #11 on: January 15, 2023, 08:39:35 pm »
Do I need Python? I have never used that
