serial transmition work with baudrate 115200kbps. It seems that I can write commands also.
here are df
command response:
df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 29868 29868 0 100% /
devtmpfs 110060 0 110060 0% /dev
none 118348 0 118348 0% /tmp
ubi1_0 29816 14388 15428 48% /usr/bin/siglent
ubi2_0 5848 72 5776 1% /usr/bin/siglent/firmdata0
ubi0_0 84752 280 84472 0% /usr/bin/siglent/usr
/dev/sda1 15711208 31136 15680072 0% /usr/bin/siglent/usr/mass_storage/U-disk0
here are the logs:
1.Booting of scope
Start menu vdma ...
Config AXI VDMA...
Start menu vdma done.
U-Boot 2014.07-svn32760 (Mar 23 2018 - 01:35:12)
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 243 MiB
NAND: 256 MiB
MMC: zynq_sdhci: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
int board_late_init(void)+++++
[INFO]int fb_display_logo(void)++++++++++++
[INFO]pStorageMem=0xfa00000, logo_data=0x200036, width=800, height=480
[INFO]int fb_display_logo(void)----------
int board_late_init(void)-----
Net: Gem.e000b000
Hit any key to stop autoboot: 0
(Re)start USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
USB1: ULPI request timed out
zynq ULPI viewport init failed
lowlevel init failed
scanning usb for storage devices... 0 Storage Device(s) found
Copying Linux from USB to RAM...
** Bad device usb 0 **
Copying Linux from NAND flash to RAM...
NAND read: device 0 offset 0x780000, size 0x400000
4194304 bytes read: OK
NAND read: device 0 offset 0xb80000, size 0x80000
524288 bytes read: OK
## Booting kernel from Legacy Image at 02080000 ...
Image Name: Linux-3.19.0-xilinx-svn8988
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3614680 Bytes = 3.4 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
EHCI failed to shut down host controller.
Loading Kernel Image ... OK
Loading Device Tree to 0e00d000, end 0e013e8b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.19.0-xilinx-svn8988 (david@david-virtual-machine) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #187 SMP PREEMPT Wed Feb 28 18:55:09 CST 2018
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Zynq Zed Development Board
[ 0.000000] cma: Reserved 16 MiB at 0x0d000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 9 pages/cpu @4edf2000 s8128 r8192 d20544 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960
[ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mtdblock5 rootfstype=cramfs init=/linuxrc earlyprintk uboot_version=08
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 220120K/245760K available (4514K kernel code, 229K rwdata, 1748K rodata, 192K init, 223K bss, 9256K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0x4f800000 - 0xff000000 (2808 MB)
[ 0.000000] lowmem : 0x40000000 - 0x4f000000 ( 240 MB)
[ 0.000000] pkmap : 0x3fe00000 - 0x40000000 ( 2 MB)
[ 0.000000] modules : 0x3f000000 - 0x3fe00000 ( 14 MB)
[ 0.000000] .text : 0x40008000 - 0x40625c7c (6264 kB)
[ 0.000000] .init : 0x40626000 - 0x40656000 ( 192 kB)
[ 0.000000] .data : 0x40656000 - 0x4068f620 ( 230 kB)
[ 0.000000] .bss : 0x4068f620 - 0x406c74c4 ( 224 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
[ 0.000000] L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[ 0.000000] slcr mapped to 4f804000
[ 0.000000] zynq_clock_init: clkc starts at 4f804100
[ 0.000000] Zynq clock init
[ 0.000011] sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
[ 0.000137] timer #0 at 4f806000, irq=17
[ 0.000507] Console: colour dummy device 80x30
[ 0.000528] Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
[ 0.090280] pid_max: default: 32768 minimum: 301
[ 0.090439] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090454] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.091117] CPU: Testing write buffer coherency: ok
[ 0.091334] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.091420] Setting up static identity map for 0x441b50 - 0x441ba8
[ 0.240268] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.240353] Brought up 2 CPUs
[ 0.240373] SMP: Total of 2 processors activated (2664.03 BogoMIPS).
[ 0.240382] CPU: All CPU(s) started in SVC mode.
[ 0.240922] devtmpfs: initialized
[ 0.241765] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.247861] NET: Registered protocol family 16
[ 0.250053] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.281232] cpuidle: using governor ladder
[ 0.311198] cpuidle: using governor menu
[ 0.319920] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.319937] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.320085] zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x4f880000
[ 0.338397] vgaarb: loaded
[ 0.338845] SCSI subsystem initialized
[ 0.339258] usbcore: registered new interface driver usbfs
[ 0.339354] usbcore: registered new interface driver hub
[ 0.339533] usbcore: registered new device driver usb
[ 0.339696] phy0 supply vcc not found, using dummy regulator
[ 0.339788] phy1 supply vcc not found, using dummy regulator
[ 0.339918] --------------usb_udc_init ------
[ 0.340147] pps_core: LinuxPPS API ver. 1 registered
[ 0.340160] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.340211] PTP clock support registered
[ 0.340340] EDAC MC: Ver: 3.0.0
[ 0.342110] cfg80211: Calling CRDA to update world regulatory domain
[ 0.342491] Switched to clocksource arm_global_timer
[ 0.355818] NET: Registered protocol family 2
[ 0.356660] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.356711] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.356769] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.356821] TCP: reno registered
[ 0.356837] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.356871] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.357079] NET: Registered protocol family 1
[ 0.357408] RPC: Registered named UNIX socket transport module.
[ 0.357421] RPC: Registered udp transport module.
[ 0.357430] RPC: Registered tcp transport module.
[ 0.357439] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.357873] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.359295] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.360980] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.362084] io scheduler noop registered
[ 0.362106] io scheduler deadline registered
[ 0.362157] io scheduler cfq registered (default)
[ 0.364345] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.364368] dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[ 0.364875] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 146, base_baud = 6249999) is a xuartps
[ 0.943761] console [ttyPS0] enabled
[ 0.947945] xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 4f878000
[ 0.954721] [drm] Initialized drm 1.1.0 20060810
[ 0.967430] brd: module loaded
[ 0.974577] loop: module loaded
[ 0.985927] libphy: MACB_mii_bus: probed
[ 1.062680] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 150 (00:0a:35:00:01:22)
[ 1.072565] macb e000b000.ethernet eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:1e, irq=-1)
[ 1.083970] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.090420] ehci-pci: EHCI PCI platform driver
[ 1.095032] usbcore: registered new interface driver usbtmc
[ 1.100611] usbcore: registered new interface driver usb-storage
[ 1.106791] e0002000.usb supply vbus not found, using dummy regulator
[ 1.113516] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.118334] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.142513] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.148689] hub 1-0:1.0: USB hub found
[ 1.152388] hub 1-0:1.0: 1 port detected
[ 1.156845] e0003000.usb supply vbus not found, using dummy regulator
[ 1.165041] i2c /dev entries driver
[ 1.169306] cdns-i2c e0005000.i2c: 20 kHz mmio e0005000 irq 144
[ 1.176565] zynq-edac f8006000.memory-controller: ecc not enabled
[ 1.182821] Xilinx Zynq CpuIdle Driver started
[ 1.187860] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.193949] usbcore: registered new interface driver r8188eu
[ 1.200381] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.206679] nand: Micron MT29F2G08ABAEAWP
[ 1.210650] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.218244] nand: WARNING: pl353-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[ 1.229708] Bad block table found at page 131008, version 0x01
[ 1.235969] Bad block table found at page 130944, version 0x01
[ 1.242072] 11 ofpart partitions found on MTD device pl353-nand
[ 1.247919] Creating 11 MTD partitions on "pl353-nand":
[ 1.253229] 0x000000000000-0x000000780000 : "fsbl"
[ 1.259101] 0x000000780000-0x000000b80000 : "kerneldata"
[ 1.265424] 0x000000b80000-0x000000c00000 : "device-tree"
[ 1.271702] 0x000000c00000-0x000001100000 : "Manufacturedata"
[ 1.278368] 0x000001100000-0x000001600000 : "reserved1"
[ 1.284559] 0x000001600000-0x000003e00000 : "rootfs"
[ 1.290488] 0x000003e00000-0x000004800000 : "firmdata0"
[ 1.296687] 0x000004800000-0x000007000000 : "siglent"
[ 1.302875] 0x000007000000-0x00000d400000 : "datafs"
[ 1.308928] 0x00000d400000-0x00000fc00000 : "upgrade_cramdisk"
[ 1.315809] 0x00000fc00000-0x000010000000 : "reserved2"
[ 1.324085] TCP: cubic registered
[ 1.327329] NET: Registered protocol family 17
[ 1.331766] lib80211: common routines for IEEE802.11 drivers
[ 1.337774] Registering SWP/SWPB emulation handler
[ 1.349485] cramfs_fill_nand blocks is 320-----------------------
[ 1.349485]
[ 1.349485]
[ 1.349485]
[ 1.362746] VFS: Mounted root (cramfs filesystem) readonly on device 31:5.
[ 1.369593] devtmpfs: mounted
[ 1.372790] Freeing unused kernel memory: 192K (40626000 - 40656000)
[ 1.482595] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.633815] hub 1-1:1.0: USB hub found
[ 1.637694] hub 1-1:1.0: 3 ports detected
Starting rcS...
Mounting filesystem
[ 1.798962] UBI-0: ubi_attach_mtd_dev:attaching mtd8 to ubi0
[ 2.201038] UBI-0: scan_all:scanning is finished
40
[ 2.760356] UBIFS: mounted UBI device 1, volume 0, name "siglent", R/O mode
[ 2.767266] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.776374] UBIFS: FS size: 33775616 bytes (32 MiB, 266 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
[ 2.786001] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.791032] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 52ED3690-D3C2-49A9-9055-7EBFF2762FCB, small LPT model
[ 2.867658] UBIFS: mounted UBI device 2, volume 0, name "firm0", R/O mode
[ 2.874396] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.883497] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[ 2.892864] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.897890] UBIFS: media format: w4/r0 (latest is w4/r0), UUID C429C489-76D4-469B-8BFE-043289ABBD0F, small LPT model
[ 2.911607] UBIFS: background thread "ubifs_bgt0_0" started, PID 675
[ 2.943197] UBIFS: recovery needed
h_mtd_dev:available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 9
[ 2.674601] UBI-2: ubi_thread:background thread "ubi_bgt2d" started, PID 670
[ 3.025920] UBIFS: recovery completed
[ 3.029594] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 3.035545] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.044644] UBIFS: FS size: 94597120 bytes (90 MiB, 745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.054276] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 3.059305] UBIFS: media format: w4/r0 (latest is w4/r0), UUID C886A817-B838-46DF-AE16-F9920045A7D7, small LPT model
Upgrade start
Configure eth0
Starting mdev
8 KiB), LEB size: 126976 bytes
[ 2.478605] UBI-1: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.487104] UBI-1: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.495793] UBI-1: ubi_attach_mtd_dev:good PEBs: 320, bad PEBs: 0, corrupted PEBs: 0
[ 2.503509] UBI-1: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.512435] UBI-1: ubi_attach_mtd_dev:max/mean erase counter: 13/9, WL threshold: 4096, image sequence number: 1819264682
[ 2.523399] UBI-1: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 320, PEBs reserved for bad PEB handling:[ 4.045576] xilinx-dma 40400000.dma: Probing xilinx axi dma engine...Successful
[ 4.087569] sigdma_init++++++
[ 4.111420] siglentkb probe
[ 4.114484] ##### siglentkb registers 4fc1e580 4fc365a4 4fc385b8
[ 4.139471] usbcore: registered new interface driver mt7601u
[ 4.152355] irq = 170
config read
###### Config vdma for wave transform #######
config write
config read
dump s2mm registers
dump mm2s registers
####### done! ########
Config vnc data to memory
Config done!
[ 4.139471] usbcore: regis[ 4.371815] UBIFS: background thread "ubifs_bgt1_0" started, PID 778
ln: /usr/bin/siglent/config/www/web_img/usr: File exists
Starting Lighttpd Web Server: Initializing framebuffer device /dev/fb0...
xres=800, yres=480, xresv=800, yresv=480, xoffs=0, yoffs=0, bpp=16
Initializing touch device /dev/input/event0 ...
Initializing VNC server:
width: 800
height: 480
bpp: 16
port: 5900
Initializing server...
01/01/1970 00:00:04 Listening for VNC connections on TCP port 5900
[ 4.504615] random: lighttpd urandom read with 17 bits of entropy available
lighttpd.
[ 4.643624] UBIFS: background thread "ubifs_bgt1_0" stops
rcS Complete
Processing /etc/profile... Done
/ # [34m[INFO]:[0mcalibrate_t():line=81:calibrate_t::calibrate_t()
product_type SDS1004X_E
mkdir: can't create directory '/usr/bin/siglent/usr/wifi/': File exists
rm: can't remove '/usr/bin/siglent/usr/wifi/wpa_supplicant': No such file or directory
$Task start:: SCPI
$Task start:: Devce
$Task start:: WLAN
$Task start:: Udisk&Lan
vxi11_main = 6821.64
$Task start:: Vxi11_client
sh: write error: Invalid argument
drv_instance_manage_t: produce_id: 13501
(DRV_PRODUCT_PIKACHU)
_drv_product=4
acq_scal_user = -1.000000
ready...
ready...
ready...
ready...
bu_cfg module error:mode-type:/usr/bin/siglent/firmdata0/options_awg_license.txt
bu_cfg module error:mode-type:/usr/bin/siglent/firmdata0/options_wifi_license.txt
bu_cfg module error:mode-type:/usr/bin/siglent/firmdata0/options_mso_license.txt
[ 7.232355] export_store: invalid GPIO 115
sh: can't create /sys/class/gpio/gpio115/direction: nonexistent directory
sh: can't create /sys/class/gpio/gpio115/value: nonexistent directory
open file %s fail !!!!/usr/bin/siglent/config/arb/2ASK.wav
scpi_register_cmd_boardtest
ready...
cp: can't stat '/usr/bin/siglent/usr/usr/save_setting.xml': No such file or directory
/usr/bin/siglent/usr/usr/save_setting.xml not exist
$Task start:: UI
ifconfig: SIOCGIFFLAGS: No such device
$Task start:: awg_thread
mod_if_exit_handler:signal=11
Clean Up Ready!
Clean Up - nlog
Clean Up - Main Thread
Clean Up - scpi
Clean Up - timer
Clean Up - dev_thread
Clean Up - ui
Clean Up - acq_thread
Clean Up - acq_data
Clean Up - draw_wave
Clean Up - bu_cfg
Clean Up - bu_main
Clean Up - bu_app
Clean Up - key
Clean Up - other
Clean Up - usbtmc
Clean Up - VXI_11
Clean Up - dev_interrupt
Clean Up - wlan_manager
Clean Up - power_off
Clean Up - telnet_scpi
Clean Up - socket_scpi
Clean Up - vxi11_client
Clean Up - Config
Clean Up - sdg_Timer
Clean Up - awg_threa[ 10.912150] Free all channel resources.
d
Clean Up - usbtmc_assistant_interrupt
Clean Up Over!
sds100[ 10.919150] Free all channel resources.
0b.app: mempool.h:81: MemoryChunk::~MemoryChunk(): Assertion `tempcount==count' failed.
2. Booting of scope with OS stored in external USB drive
Start menu vdma ...
Config AXI VDMA...
Board: Xilinx Zynq
I2C: ready
NAND: 256 MiB
MMC: zynq_sdhci: 0
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
(Re)start USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 3 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
** Invalid partition 1 **
Starting kernel ...
enabled
0.356649] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.356703] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.356761] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.356810] TCP: reno registered
[ 0.356828] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.356863] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.357070] NET: Registered protocol family 1
[ 0.357416] RPC: Registered named UNIX socket transport module.
[ 0.357429] RPC: Registered udp transport module.
[ 0.357438] RPC: Registered tcp transport module.
[ 0.357447] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.359290] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.360978] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.362068] io scheduler noop registered
[ 0.362090] io scheduler deadline registered
[ 0.362140] io scheduler cfq registered (default)
[ 0.364310] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.364330] dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[ 0.364832] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 146, base_baud = 6249999) is a xuartps
[ 0.943655] console [ttyPS0] enabled
[ 0.947840] xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 4f878000
[ 0.954616] [drm] Initialized drm 1.1.0 20060810
[ 0.967322] brd: module loaded
[ 0.974502] loop: module loaded
[ 0.985953] libphy: MACB_mii_bus: probed
[ 1.062452] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 150 (00:0a:35:00:01:22)
[ 1.072328] macb e000b000.ethernet eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:1e, irq=-1)
[ 1.083738] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.090186] ehci-pci: EHCI driver usb
[ 0.339429] phy0 supply vcc not found, using dummy regulator
[ 0.339536] phy1 supply vcc not found, using dummy regulator
[ 0.339670] --------------usb_udc_init ------
[ 0.339897] pps_core: LinuxPPS API ver. 1 registered
[ 0.339911] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.339967] PTP clock support registered
[ 0.340296] EDAC MC: Ver: 3.0.0
[ 0.341900] cfg80211: Calling CRDA to update world regulatory domain
[ 0.342332] Switched to clocksource arm_global_timer
[ 0.355865] NET: Registered protocol family 2
[ tch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode PCI platform driver
[ 1.094784] usbcore: registered new interface driver usbtmc
[ 1.100365] usbcore: registered new interface driver usb-storage
[ 1.106534] e0002000.usb supply vbus not found, using dummy regulator
[ 1.113235] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.118047] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.142353] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.148519] hub 1-0:1.0: USB hub found
[ 1.152214] hub 1-0:1.0: 1 port detected
[ 1.156695] e0003000.usb supply vbus not found, using du2c: 20 kHz mmio e0005000 irq 144
[ 1.176481] zynq-edac f8006000.memory-controller: ecc not enabled
[ 1.182760] Xilinx Zynq CpuIdle Driver started
[ 1.187808] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.193902] usbcore: registered new interface driver r8188eu
[ 1.200310] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.206606] nand: Micron MT29F2G08ABAEAWP
[ 1.210572] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.218145] nand: WARNING: pl353-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[ 1.229703] Bad block table found at page 131008, version 0x01
[ 1.235974] Bad block table found at page 130944, version 0x01
[ 1.242082] 11 ofpart partitions found on MTD device pl353-nand
[ 1.247931] Creating 11 MTD partitions on "pl353-nand":
[ 1.253145] 0x000000000000-0x000000780000 : "fsbl"
[ 1.259061] 0x000000780000-0x000000b80000 : "kerneldata"
[ 1.265382] 0x000000b80000-0x000000c00000 : "device-tree"
[ 1.271670] 0x000000c00000-0x000001100000 : "Manufacturedata"
[ 1.278360] 0x000001100000-0x000001600000 : "reserved1"
[ 1.284536] 0x000001600000-0x000003e00000 : "rootfs"
[ 1.290490] 0x000003e00000-0x000004800000 : "firmdata0"
[ 1.296725] 0x000004800000-0x000007000000 : "siglent"
[ 1.302817] 0x000007000000-0x00000d400000 : "datafs"
[ 1.308894] 0x00000d400000-0x00000fc00000 : "upgrade_cramdisk"
[ 1.315820] 0x00000fc00000-0x000010000000 : "reserved2"
[ 1.324034] TCP: cubic registered
[ 1.327276] NET: Registered protocol family 17
[ 1.331716] lib80211: common routines for IEEE802.11 drivers
[ 1.337825] Registering SWP/SWPB emulation handler
[ 1.349593] cramfs_fill_nand blocks is 320-----------------------
[ 1.349593]
[ 1.349593]
[ 1.349593]
[ 1.363081] VFS: Mounted root (cramfs filesystem) readonly on device 31:5.
[ 1.369933] devtmpfs: mounted
[ 1.373116] Freeing unused kernel memory: 192K (40626000 - 40656000)
[ 1.472440] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.623754] hub 1-1:1.0: USB hub found
[ 1.627935] hub 1-1:1.0: 3 ports detected
Starting rcS...
Mounting filesystem
[ 1.804378] UBI-0: ubi_attach_mtd_dev:attaching mtd8 to ubi0
[ 2.206471] UBI-0: scan_all:scanning is finished
[ 2.218867] UBI-0: ubi_attach_mtd_dev:attached mtd8 (name "datafs", size 100 MiB)
[ 2.226325] UBI-0: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.234884] UBI-0: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.243387] UBI-0: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.252052] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
[ 2.259802] UBI-0: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.268735] UBI-0: ubi_attach_mtd_dev:max/mean erase counter: 10/4, WL threshold: 4096, image sequence number: 950638423
[ 2.279582] UBI-0: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 800, PEBs reserved for bad PEB handling: 40
[ 2.290534] UBI-0: ubi_thread:background thread "ubi_bgt0d" started, PID 662
[ 2.294871] UBI-1: ubi_attach_mtd_dev:attaching mtd7 to ubi1
[ 2.456155] UBI-1: scan_all:scanning is finished
[ 2.467921] UBI-1: ubi_attach_mtd_dev:attached mtd7 (name "siglent", size 40 MiB)
[ 2.475371] UBI-1: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.483930] UBI-1: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.492433] UBI-1: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.501232] UBI-1: ubi_attach_mtd_dev:good PEBs: 320, bad PEBs: 0, corrupted PEBs: 0
[ 2.508958] UBI-1: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.517855] UBI-1: ubi_attach_mtd_dev:max/mean erase counter: 13/9, WL threshold: 4096, image sequence number: 1819264682
[ 2.528786] UBI-1: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 320, PEBs reserved for bad PEB handling: 40
[ 2.539818] UBI-1: ubi_thread:background thread "ubi_bgt1d" started, PID 666
[ 2.544307] UBI-2: ubi_attach_mtd_dev:attaching mtd6 to ubi2
[ 2.586871] UBI-2: scan_all:scanning is finished
[ 2.597656] UBI-2 warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 9, need 40
[ 2.608741] UBI-2: ubi_attach_mtd_dev:attached mtd6 (name "firmdata0", size 10 MiB)
[ 2.616346] UBI-2: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.624925] UBI-2: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.633428] UBI-2: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.642096] UBI-2: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[ 2.649747] UBI-2: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.658688] UBI-2: ubi_attach_mtd_dev:max/mean erase counter: 10/6, WL threshold: 4096, image sequence number: 1777018790
[ 2.669646] UBI-2: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 9
[ 2.680416] UBI-2: ubi_thread:background thread "ubi_bgt2d" started, PID 670
[ 2.742578] usb 1-1.2: new high-speed USB device number 3 using ci_hdrc
[ 2.767135] UBIFS: mounted UBI device 1, volume 0, name "siglent", R/O mode
[ 2.774059] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.783150] UBIFS: FS size: 33775616 bytes (32 MiB, 266 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
[ 2.792774] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.797803] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 52ED3690-D3C2-49A9-9055-7EBFF2762FCB, small LPT model
[ 2.874537] UBIFS: mounted UBI device 2, volume 0, name "firm0", R/O mode
[ 2.881260] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.890386] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[ 2.895761] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 2.899916] scsi host0: usb-storage 1-1.2:1.0
[ 2.910329] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.915380] UBIFS: media format: w4/r0 (latest is w4/r0), UUID C429C489-76D4-469B-8BFE-043289ABBD0F, small LPT model
[ 2.929148] UBIFS: background thread "ubifs_bgt0_0" started, PID 682
[ 2.960826] UBIFS: recovery needed
[ 3.026853] UBIFS: recovery completed
[ 3.030538] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 3.036487] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.045634] UBIFS: FS size: 94597120 bytes (90 MiB, 745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.055228] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 3.060251] UBIFS: media format: w4/r0 (latest is w4/r0), UUID C886A817-B838-46DF-AE16-F9920045A7D7, small LPT model
Upgrade start
Configure eth0
Starting mdev
[ 3.893675] scsi 0:0:0:0: Direct-Access Generic Flash-Disk 1.09 PQ: 0 ANSI: 2
[ 3.904053] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.909788] sd 0:0:0:0: [sda] 15728640 512-byte logical blocks: (8.05 GB/7.50 GiB)
[ 3.919526] sd 0:0:0:0: [sda] Write Protect is off
[ 3.926123] sd 0:0:0:0: [sda] No Caching mode page found
[ 3.931375] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3.945598] sda:
[ 3.953257] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.106171] xilinx-dma 40400000.dma: Probing xilinx axi dma engine...Successful
[ 4.132424] xilinx-vdma 43010000.dma: Xilinx AXI VDMA Engine Driver Probed!!
[ 4.148108] sigdma_init++++++
[ 4.171856] siglentkb probe
[ 4.174840] ##### siglentkb registers 4fc3c580 4fc3e5a4 4fc525b8
[ 4.201999] usbcore: registered new interface driver mt7601u
[ 4.215120] irq = 170
config read
config write
config read
dump s2mm registers
dump mm2s registers
Config done!
[ 4.434381] UBIFS: background thread "ubifs_bgt1_0" started, PID 792
width: 800
height: 480
bpp: 16
port: 5900
[ 4.619329] random: lighttpd urandom read with 27 bits of entropy available
lighttpd.
[ 4.757138] UBIFS: background thread "ubifs_bgt1_0" stops
rcS Complete
/ # [ 5.064577] macb e000b000.ethernet eth0: link up (100/Full)
$Task start:: SCPI
$Task start:: Devce
$Task start:: WLAN
vxi11_main = 6861.09
drv_instance_manage_t: produce_id: 13501[ 6.916941] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
_drv_product=4
eth0 on
[ 6.984507] device eth0 entered promiscuous mode
ready...
ready...
ready...
ready...
[ 7.336193] export_store: invalid GPIO 115
ready...
$Task start:: UI
Clean Up Ready!
Clean Up - nlog
Clean Up - scpi
Clean Up - timer
Clean Up - ui
Clean Up - acq_data
Clean Up - bu_cfg
Clean Up - bu_main
Clean Up - bu_app
Clean Up - key
Clean Up - other
Clean Up - usbtmc
Clean Up - VXI_11
Clean Up - Config
Clean Up - awg_thread
Clean Up Over!
sds1000b.app: mempool.h:81: MemoryChunk::~M[ 11.072046] Free all channel resources.
tempcount=0,[ 11.077790] Free all channel resources.
3. Start sds1000b.app commnd
/usr/bin/siglent/sds1000b.app &
[1]- Aborted /usr/bin/siglent/sds1000b.app
$Task start:: SCPI
route: SIOCADDRT: File exists
$Task start:: Devce
sh: write error: Device or resource busy
vxi11_main = 1.89248e+06
_drv_product=4
$Task start:: WLAN
[ 1892.568522] export_store: invalid GPIO 115
ready...
ready...
ready...
ready...
ready...
$Task start:: UI
Clean Up Ready!
Clean Up - nlog
Clean Up - scpi
Clean Up - timer
Clean Up - ui
Clean Up - acq_data
Clean Up - bu_cfg
Clean Up - bu_main
Clean Up - bu_app
Clean Up - key
Clean Up - other
Clean Up - usbtmc
Clean Up - VXI_11
Clean Up - dev_interru[ 1894.929648] Free all channel resources.
pt
Clean Up - te[ 1894.937666] Free all channel resources.
lnet_scpi
Clean Up - Config
Clean Up Over!
sds1000b.app: mempool.h:81: MemoryChunk::~MemoryChunk(): Assertion `tempcount==count' failed.
