Today I finished one thing in the morning, and expected to be going out for the rest of the day. But had a short block of spare time. Did a little tidying, and came across an old relic that I'd previously attempted to open out of curiosity, but failed. This time I thought I'd have another go, briefly. Just to have a look.
It's like a hand-cranked megger, but more complicated. I don't have any information on it or how to use it, so didn't even know if it works. But it's old and interesting, and on my 'look into' list. Badly needs restoration.
Many of the case screws are sealed with hammered-in lead plugs. I'd previously removed the lead plugs from the case top, and removed those screws. But the top still didn't come off. Something inside holding it loosely.
This time I opened the bottom. Success!
Then the afternoon's expected activity didn't happen. So I just kept on mucking around with this thing, in general fixing what's broken and starting on cleaning. Still don't know what it is, exactly.
But it looks cool.
Because of the random whim start, I didn't take overall photos first. There are some later.
The lead seals are stamped with the manufacturer's logo: SEV with a pi symbol.
Base - nothing special, just a lot of scratched bakelite and the usual completely failed ancient rubber feet.
Inside - Wow. *LOTS* of soldered fine adjustments everywhere, and not a flexible wire in sight. The blue thing is a surprise - bright blue plastic of some kind, in an ancient thing like this?
Screw missing - One of the contacts of the mode selection switch is hanging loose. Might as well fix it...
Not all missing - I'd thought it had stripped out of a threaded hole in the bakelite. but no. There is the nut, and other half of the screw still in place. It actually sheared in half. Over tightened plus corrosion I guess.
Fixed - This was _such_ a hassle. I have a large assortment of very small screws from all sources, but not one that fit that square nut. So I had to make a square nut that would fit a similar screw I found. Plus drill out the bakelite hole very slightly to fit that screw. Which meant a long hunt for that odd sized small drill bit...
Decades _ seemed like decades later. One thing that most needs repair, is the plastic windows to the numbers on this row of decade resistors. They are disintegrating. Once I had the box open, it was possible to remove this. just unsolder two wires. Then struggle to jigsaw-maneuver it out, without bumping any of the very fragile looking tiny wires neatly wound in freestanding coils to trim each of the resistances. This thing was NOT made for easy disassembly.
Wipers - to get to the 'windows', everything has to be removed from the front panel. But first I tried measuring the resistance end-to-end while moving the dials. Hopeless... really bad contacts everywhere, and not improving with repeated wiping. So continue disassembling.
Dirty. Oh I see. That black stuff does not wipe off easily. Not even with solvents. Some kind of chemical reaction between a grease and the copper. OK, there's a quick brute force way to deal with that. (Not involving explosives, though tempting.)
Clean. Emory paper and a cork block. Now the contacts are clean. When putting it back together I'll try lithium soap grease, see how that goes. Unless anyone has a better suggestion.
