Hi all,
I have gotten in my hands a "semi" working IEC F34 Function Generator. The problem is that it does not in any shape or form have a stable waveform. Usually there is a lot of amplitude modulation on the signal.
Law of electronics repair #1: "Thou shalt check voltages."
Luckily, this device is from the early 70s! when they still knew hot to put nice pretty test points in everywhere. (And the manual is awesome.) Manual is attached.
Anyway, it has a split supply +-15 and +- 5 V. Both positive rails are dead on, but the negative 15V rail measures -12.## and the -5 measures -4.5.
So, I checked the manual (attached), and it says "Q31 or Q32 shorted" for the problem of "-5V rail too high." Technically the -5V rail is too "high", but it all depends on what you consider high with negative numbers. The other problem of "-5V rail too low" is simply Q31 or Q32 open". Neither of which is true. I don't know how a transistor can be shorted, but both had 10s of kOhms between the pins. I'm not sure how else to check them.
Regardless, I then checked voltages on the pins of the transistors, there I found my -12.## and -4.5 Vs. I think the -4.5 is due to the -12.##. So, Then I ran into a block. I tried looking into the parts list for voltage regulators... but I don't think they were around back then, cause all they have are zener diodes. Which, sure, can be used as voltage regulators in a way.
Anyway, I'm waiting until tomorrow to print out the schematic, it's next to impossible to look at on the computer (it's split over multiple pages.)
But, if you guys want to take a crack at it, I'd be mighty grateful.
NINJA EDIT: I found a cracked joint on the 2500uF electrolytic (they're wicked old, and look like they have a wooden top?) Maybe I'll replace them anyway, they're probably dead by now anyway right? They have 4 pins, but I think 2 are there for support (aka no traces go to them.)
Attached is the manual for the 30 Series Function Generator from IEC. F34 F33 F32 F31 (For google because I sure had a hell of a time finding the damn thing, I hope that's ok.)
EDIT: Ok it's not attached, but here is the link. It's 10mB so the forums didn't like it ;(
https://drive.google.com/file/d/0B6oqWuYTCiclOUI0d1RzSVRROXM/edit?usp=sharingEDIT for pictures! Ok so I don't know how to edit and add pictures... I shall make another post.
