The 2830 looks like a good machine; but it's pushing my budget.
Is there anything I've missed or should consider?
Hi Giallograle,
since the meter has not been mentioned you might like to take a look at the Matrix MCR-5200 as option. It measures up to 200kHz, can be
programmed and is avilable new for ~650-750€ for instance at
eleshop or
digikey. The meter supports a fixed set of measurement frequencies (40Hz, 50Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 200Hz, 250Hz, 300Hz, 400Hz, 500Hz, 600Hz, 800Hz, 1kHz, 1.2kHz, 1.5kHz, 2kHz, 2.5kHz, 3kHz, 4kHz, 5kHz, 6kHz, 7.5kHz, 10kHz, 12kHz, 15kHz, 20kHz, 25kHz, 30kHz, 40kHz, 50kHz, 60kHz, 75kHz, 100kHz, 120kHz, 150kHz, 200kHz). There is also a Matrix 6000 Series with contiguous frequency support or the big Brother
MCR-8500 which measures up to 5MHz but is considerably more expensive (around 4500€)
Cheers Traceless
