Author Topic: Upgraded/jailbreaked(?) Rigol scope - updating software/firmware safe?...  (Read 2288 times)
Offline RaxTopic starter
I've just been handed an upgraded Rigol 1052E which effectively became a 1102E. There's tons of posts and videos on this, including one from Dave.
I'm positive this has been discussed at length, but what's the situation with the scope at this point? Can I use the Rigol software freely (I'm apprehensive about some sort of reports back to Rigol this was hacked), can I mess with the firmware (such as upgrading it), can I take this online and hook up my computer to it and all that good stuff? Will I get in any trouble, and secondly, will anything get disabled on the scope?
Thank you very much for your input.
Offline wasedadoc
Stop being paranoid.  :)
If it'd only be so easy...  :scared:
But seriously, I am concerned about hooking up the scope to their software to maybe find it disables something, or won't communicate or whatnot. Probably still paranoid to ask these questions, but I guess my overall question is if there's any limitations at all with running an "upgraded" scope with all available software and also online.
  • Can I freely upgrade the firmware?
  • Can I run selfcalibration with not concern it bricks or whatever?
Etc.
Offline tv84
  • Country: pt
1. Take it to Cheyenne Mountain together with an UPS and turn it on only at night. Don't say nothing to anybody!
2. Use it galore.
Your choice.
Your choice.
Humbly, I don't think you understand how different the countries we live in (you and I) truly are.
Regardless, my question is of a more practical nature than that.
Offline Fungus
You claim to have read "tons of posts and videos" on the subject.
Did you find a single one where the Rigol police knocked on somebody's door at 4am? (or whatever)
... including one from Dave.
Did Dave mention any problems?
Offline jpanhalt
I have been using my upgraded Rigol DS1054 for about 7 years.  No problem.  In fact, as I recall, Rigol seemingly but not officially approved the upgrade as a great marketing tool.  I love it when a company's bosses can actually think.  Later they offered the fully upgraded scope at about the same price.  I suspect the same philosophy will apply in your case.
Of course, absence of reports of Rigol being malicious to upgraders is not proof it it isn't or won't be.  I think it is pretty unlikely, though.
The following users thanked this post: Rax
Online kripton2035
especially for such an old scope model as the 1052E ...
Offline tv84
  • Country: pt
    Etc.
    I think the major differences in using that device, in both our countries, are: 110V/60Hz and 230V/50Hz.  ;)
    Not at all.
    Excellent, thank you. Very helpful input and what I was hoping my OP would harvest.
    Well, I'll take your input as hopeful, though with a whiff of spicy humor... (which I appreciate). Thank you.
    Offline Fungus
    The clue was in the fact the the entire world does it...  :-//
    That's never stopped me from taking a closer look and doing my due diligence. YMMV.
    « Last Edit: May 15, 2023, 04:19:39 am by Rax »
    ....interestingly, installing the driver and other software components for the scope seems to rely on some "compliance package" from NI. Is there some known affiliation between Rigol and National Instruments? I wasn't aware this is the case. Does sound potentially quite a bit more... enforcey. At least in the US.
    « Last Edit: May 15, 2023, 03:38:51 am by Rax »
    Offline .RC.
    If a manufacturer sells a product whereby the end user can click a setting with the already installed software that enables something that the product already has installed would be nothing wrong with that.  They cannot come around with the SWAT team bash the door down screaming software infringement as you did not install anything like pirated software on the device.  All you did was essentially change a setting in the software.  You were doodling around and tapped a random string of charactors you thought up into the device and it seemed to do something.
    Now if the change required new software to be installed that had to be bought from the supplier and you did not buy it but rather "found" a copy.   Then that is copyright infringement.
    Offline Fungus
    Oh, no... you didn't install that NI junk did you? It's absolutely not needed.
    The scope driver, at least in its current iteration, would refuse to install without the NI components.
    Offline Fungus
    Why exactly do you need a "driver"?
    Offline coromonadalix
    I think you should have stayed in the already made threads about rigols models hacks,
    Your OP harvest thing ???
    I still dont know where you're going to ??   Useless post ...
    I have some Rigols at my job,  Rigols do have some softwares ..  And they mostly work without adding the NI stuff since they have some in them
    they are Hacked / Upgraded  and they still work with Rigol softwares, absolutely no problems.
    You should do some reading about your driver thing
    From NI:
    NI-VISA provides support for customers using Ethernet, GPIB, serial, USB, and other types of instruments.
    NI-VISA is an NI instrument driver that is an implementation of the Virtual Instrument Software Architecture (VISA) I/O standard. VISA is a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, serial (RS232/RS485), Ethernet/LXI, and/or USB interfaces. NI-VISA includes utilities, low-level control features, and examples to help you create your application.
    VISA allows for the development of programs to be bus independent ....
    « Last Edit: May 15, 2023, 06:56:24 am by coromonadalix »
    Offline Fungus
    Yeah, but only horrible industrial software tries to use VISA.
    Everybody else uses SCPI which doesn't need any drivers - it's just an IP connection.
    https://www.batronix.com/pdf/Rigol/ProgrammingGuide/DS1000DE_ProgrammingGuide_EN.pdf
    Offline Miti
    You may need a patent lawyer …  :palm:
    The land of the free!
    Fear does not stop death, it stops life.
    But sadly  some brand are poorly documented ... trials and errors ....  i would prefer SCPI too
    Getting rid of  NI visa stuff, bad compatibility  etc ... had problems with Keysight ones, ended up using R&S  packages and worked better with a smaller footprint
    And yes  using Labview to create a front end for an Siglent generator was a nightmare,  way outdated help or examples on the web, i created an labview executable, need basic Labview packages to run it
    But i need it to save tons of manipulations on the generator itself, i have an TTI generator showing wear and tear on the encoder wheel ... have to generate tons of different frequencies and levels to test very specific boards
    To have an fully independant executable outside Labview cost $$$
