Author Topic: Upgrading DSLogic Basic to Plus without EEPROM modification  (Read 10647 times)
Offline matbob
« on: March 10, 2019, 04:00:02 am »
Hello All,
I would like to share my experience with upgrading the DSLogic Basic to Plus. I saw discussions in EEVblog forum where some people were able to upgrade the basic version to plus version by soldering the 256Mbit RAM chip and renaming the firmware files (DSLogicBasic.fw/bin replaced by DSLogicPlus.fw/bin and renamed to *Basic.fw/bin). Even after these two steps, some were not able to get the upgrade and they had to modify the EEPROM content. The USB device PID in the EEPROM had to be changed to match the Plus version so that the DSView software recognizes the device as DSLogic Plus hardware.
Now, I will tell my story. I bought a DSLogic Basic clone from Ebay and I wanted to upgrade it to Plus. I bought the 256Mbit RAM and soldered it. I downloaded the DSView V0.99 from DreamSourceLab website and compiled and installed it (on Fedora 28, fingers crossed, installed successfully!). I ran the software, connected the hardware and it got detected as DSLogicBasic. Then I checked for the location in my PC where the firmware files are located, I found it was at: "/usr/local/share/DSView/res". I backed up all the files in the folder (you will need root privilages). Then I deleted the DSLogicBasic.fw and DSLogicBasic.bin files and made copies of DSLogicPlus.fw and DSLogicPlus.bin files and renamed them to DSLogicBasic.fw and DSLogicBasic.fw. By this step, the idea is to load the Plus firmware to the Basic (+RAM) hardware the next time the DSView software starts up. I opened DSView and connected my hardware, but it got detected only as DSLogic Basic.
So, the DSView software is checking the PID of the USB device to determine which version it is. Obviously, the PID was not getting modified by changing the firmware from Basic to Plus. The PID is stored inside the EEPROM and for the DSView software to recognize the hardware as Plus version, the EEPROM content had to be modified. I had a PICkit3 with me and I thought I will desolder the EEPROM, solder on a protoype board, solder the wires from PICkit3, read the EEPROM contents, modify the PID value at 2 locations (as suggested in another forum), write it back and solder it back. Unluckly, PICkit3 does not support EEPROM programming without a hardware hack. I did not want to do the hardware hack (beacuse the PICkit3 does not belong to me).
But I wanted to check that even though the DSView software recognized my hardware as Basic version, will it be capable of delivering the performace of the Plus version because the hardware and firmware is Plus version and only the PID is of Basic version. I checked the DSView software's user guide. The guide says that in the buffer mode, the maximum sample duration is given by: (maximum duration = hardware depth / sample rate / number of channels used). At 400MHz sample rate with 4 channels enabled, for a DSLogicBasic with 256Kbit memory, the maximum duration corresponds to: (256 x 1024 / 400M / 4) = 163.84us. For a DSLogicPlus with 256Mbit memory, the maximum duration is (256 x 1024 x 1024 / 400M / 4) = 167.77 ms! With my hardware (with the extra RAM and Plus firmware) I could see that in the DSView software, maximum duration is only 163.84us. That means the software is limiting the functionality even though the hardware is capable.
Now comes the interesting part. The DSView program was complied from the source. So, in the source code, there will be some place where the PIDs of the devices are defined. After a few minutes of searching, I found the file: .../DSView-0.99/libsigrok4DSL/hardware/DSL/dsl.h in which the DSLogic "profiles" for each version are defined. It was not very difficult to understand. I modified the following lines in the code:
    {0x2A0E, 0x0021, "DreamSourceLab", "DSLogic Basic", NULL,
     "DSLogicBasic.fw",
     "DSLogicBasic.bin",
     "DSLogicBasic.bin",
    {CAPS_MODE_LOGIC,
      CAPS_FEATURE_VTH,
      (1 << DSL_STREAM20x16) | (1 << DSL_STREAM25x12) | (1 << DSL_STREAM50x6) | (1 << DSL_STREAM100x3) |
      (1 << DSL_BUFFER100x16) | (1 << DSL_BUFFER200x8) | (1 << DSL_BUFFER400x4),
      SR_KB(256),
      0,
      DSL_STREAM20x16,
      0,
      0,
      DSL_STREAM20x16,
      SR_MHZ(1),
      SR_Mn(1),
      0,
      0}
to:
     "DSLogicBasic.fw",
     "DSLogicBasic.bin",
     "DSLogicBasic.bin",
     {CAPS_MODE_LOGIC,
      CAPS_FEATURE_VTH | CAPS_FEATURE_BUF,
      SR_MB(256),
      0,
      DSL_BUFFER100x16,
      0,
      0,
      DSL_STREAM20x16,
      SR_MHZ(1),
      SR_Mn(1),
      0,
      0}
I assume that the modification is self explanatory if you go through the code. 0x2A0E is VID, 0x0021 is PID of Basic version, the SR_KB(256) is modified to SR_MB(256).... By this modification, I force the software to use the features offered for Plus hardware for the Basic hardware (already upgraded to Plus) as well. After this, I compiled and installed DSView again. This time also the name of the hardare appeared as DSLogic Basic (becasue I did not modify this in the source) but I see that the maximum duration available with my hardware is 167.77 ms!
The only catch is that if you connect a Basic hardware without the RAM soldered to the hacked DSView software, it will use the Plus firmware and because the RAM is not available, it won't show any results. But as long as you have only one hardware with the RAM soldered to it, this method works well.
The following users thanked this post: egonotto, thm_w, coromonadalix, RoGeorge, analogRF
Offline tsman
Re: Upgrading DSLogic Basic to Plus without EEPROM modification
« Reply #1 on: March 10, 2019, 04:19:57 am »
Using the CyConsole tool didn't work for reprogramming the EEPROM?
Offline matbob
« Reply #2 on: March 10, 2019, 10:12:52 pm »
Hello tsman,
Thanks for the comment. I was unaware of CyConsole. I went online and read about this software, it seems that it is a tool in the Cypress SuiteUSB which is available only for Windows. I run Linux (Fedora) on my  PC and therefore I can't try this.
If I want to modify the PID in the EEPROM, I should be knowing the address where the PID is stored. According to this post in one of the forums: https://time4ee.com/news.php?readmore=453, there are 2 locations: 00000003 and 0000186A. The value has to be changed from 0x21 (PID of Basic) to 0x20 (PID of Plus). This might be possible using CyConsole. Please let me know whether you have successfully tried this. This would be much elegant method rather than modifying the DSView software.
Thank you.
Offline Microcheap
« Reply #3 on: March 15, 2019, 03:45:55 pm »
I just upgraded my DSLogic Basic to the Plus version and I can confirm that it works. The steps I followed:
1- I got the MT48LC16M16A2-6A SDRAM IC from here https://www.aliexpress.com/item/in-stock-can-pay-MT48LC16M16A2-TG-75D-MT48LC16M16A2P-6A-MT48LC16M16A2TG-7E-MT48LC32M16A2-5pcs-lot/32805462396.html
2- Desoldered the EEPROM from the LA board (U4) and attached it to a programmer like this https://www.aliexpress.com/item/SOIC8-SOP8-Test-Clip-For-EEPROM-93CXX-25CXX-24CXX-CH341A-24-25-Series-EEPROM-Flash-BIOS/32898599200.html I used a DIP8-SOIC8 adapter.
3- Read the EEPROM and save a backup just in case. Search for the Hex values "0E2A2100" and change it to "0E2A2000" (It appears 2 times, you need to change both). I've used HxD editor to edit the file extracted from the memory.
4- Just reprogram the EEPROM e solder the ICs to the board.
5- Now, when you open DSView it should identify the device as DSLogic Plus, no need to rename firmware files.
The following users thanked this post: coromonadalix, nb2000
Offline cv007
« Reply #4 on: March 15, 2019, 11:09:44 pm »
This happened before-
https://www.eevblog.com/forum/testgear/dslogic-plus/msg2011508/#msg2011508
Simply rename the fw file from Plus to Basic. That's it.
I wonder if maybe the eeprom firmware has changed on newer ones where the fw file is no longer loaded/needed?
It seems odd that I can rename the fw file all day long (0.9.8,0.9.9) and switch between Plus/Basic, and some others don't seem to be able to.
If there is a newer eeprom firmware on newer ones, one way to check would be to remove all fw files and see if dsview is still happy (or if on Windows, just listen for the usb detection/re-enumerate when dsview starts).
Offline bianchifan
« Reply #5 on: May 05, 2019, 11:59:05 am »
Me too... :)
3- Read the EEPROM ...
4- Just reprogram the EEPROM ...
I'm sad but this didn't work for me :((
Taking a closer look at the EEPROM it identifies itself as 4128BRP form ST -> M24128
UNfortunately it seems not to be supported by CH341A programmer, ST Chips are listed only within 24C01 - 24C64, no C128 , no M-types..
So i ordered a couple of Atmel Chips on ebay and hope...
For the meanstime I edited the sources, DSView and PulseView, similar as mentioned above.
DSView recons the unit just at the moment of connection, PulseView not.
First you must connect the device and afterwards start Pulseview... :-//
Offline Microcheap
« Reply #6 on: May 05, 2019, 04:17:39 pm »
Just select any common EEPROM chip form the menu like the 24C128 (supposing you are using the same CH341 programmer as me) that it should work.
Did you de-soldered the chip from the board? The programmer will not work if you try to read the eeprom with the IC on the board, you have to remove it. I then used an adapter like this https://www.aliexpress.com/item/1PCS-150mil-SOIC8-SOP8-to-DIP8-EZ-Programmer-Adapter-Socket-Converter-Module-Suitable-for-ALL-11/32900742229.html attached to the CH341 ZIF socket.
Offline fonak
« Reply #7 on: May 28, 2019, 05:51:26 pm »
Hello,
I tried the method of replacing the firmware in the eeprom and soldered the ram's memory. Unfortunately, my dslogic is not working. The DSView application sees the analyzer as a plus version, but giving a rectangular signal to inputs has no effect - it is always zero. Return to the old version (Basic) of the eeprom without changing the VID and PID returns the analyzer to normal operation (square wave). I also checked the random memory pins of the oscilloscope and see that communication occurs.
Can anyone share a working hex file for the plus version.
PS. File from the thread https://time4ee.com/news.php?readmore=453
it gives the same effect as I wrote above.
Regards
« Last Edit: May 28, 2019, 06:59:12 pm by fonak »
Offline TheNewLab
« Reply #8 on: August 03, 2019, 05:49:05 am »
Did you get the Basic to work again? have you tried again to upgrade it to a Plus?
I had a random thought. that RAM add on to make it a Plus is 256MB,
Has anyone tried 512MB? Is it doable? double the amount of RAM of the Plus version?
Offline fonak
« Reply #9 on: August 04, 2019, 09:12:49 am »
Hello
1. Yes the Basic version works without problems (with BASIC firmware version), even with soldered 256MB RAM chip.
2. Yes, I tried two times, but without any effects. The software (v0.99) sees the plus version, however, after entering the rectangular signal to input, the DSView software always sees zero.
3. I have not tried to use 512 MB.
« Last Edit: August 04, 2019, 09:19:26 am by fonak »
Offline pgo
« Reply #10 on: August 05, 2019, 03:30:20 am »
Just to provide another data point.
I purchased a DSLogic basic on ebay.  I was confused and thought it was the Plus.
I added the SDRAM chip (https://au.element14.com/micron/mt48lc16m16a2p-6a/sdram-256mbit-167mhz-54tsop/dp/2253737)
see https://time4ee.com/news.php?readmore=453 for intial information (but don't remove the EEPROM!)
Method 1 - no EEPROM changes required
I then (under windows) patched the DSView program.  It is necessary to search for the PID/VID for the basic and change it so that it doesn't detect the Basic one and then modify the PID/VID for the Plus so that it is the Basic (two bytes modified).  This effectively makes the software accept the basic as plus.  The PID/VID are in little-endian order. (DSView.exe, Offset EE9AC2, EE9B52.)
Method 2 - Re-program EEPROM in-situ
Wire pin 7(WC) to pin 4(Gnd) on the EEPROM.  This disables the write protect. This can be done with  a fine wire e.g. wire-wrap. This is safe because pin 7 only has a pull-up to Vdd.
This allows the EEPROM to be programmed by the Cypress USB chip over the USB from a PC.
A program to do this is available at https://github.com/podonoghue/LogicAnalyser/tree/master/Software/fx2lafw_eeprom_loader
The required EEPROM images are available if you search on the web or you can simply download the image from the DSLogic and patch the PID/VID and reprogram.
You may remove the link after programming but there is no requirement.
bye
Edit to clarify.
« Last Edit: August 06, 2019, 12:48:34 am by pgo »
Offline fonak
« Reply #11 on: August 05, 2019, 05:27:23 pm »
Hello pgo
Thanks for the information, I will try to upgrade the analyzer according to your suggestion this coming weekend.
I have an question. Which file in the DSview app you patched?
At the moment I found hex file only on this page: https://time4ee.com/news.php?readmore=453
and I have used them without success.
files:
The 24C128 EEPROM content file
https://mega.nz/#!j8p3iSZB!-L7zwI02reZQz0ASXzjAxWUnioAEUW1Z70uJY6H2oNQ
Regards
« Last Edit: August 05, 2019, 05:58:48 pm by fonak »
Offline Microcheap
« Reply #12 on: August 05, 2019, 10:06:54 pm »
You don't need to change any file in the DSview, just solder the SDRAM chip and desolder the EEPROM. Read the EEPROM chip that you just removed from the board with a eeprom reader. Save the extracted content, that is your HEX file, then edit it to change the PID/VID, save it and reprogram the eeprom using this modified HEX file. Solder the IC back to the board, if everything is correct, the DSview will identify your LA as the Plus version.
I've posted a more detailed explanation (with pics) a few threads above.
There was another method that involved renaming some files in the DSview folder, but it did not work for me and if you reinstall the software or change the computer you would have to rename the files again. Reprogramming the EEPROM worked fine and is a more permanent solution.
« Last Edit: August 05, 2019, 11:13:49 pm by Microcheap »
Offline pgo
« Reply #13 on: August 06, 2019, 12:36:14 am »
Hi Fonak,
I edited DSView.exe.
Hi Microcheap -
Not everyone has access to a programmer!
It is easier to solder one wire than remove the EEPROM.
It easier to program the chip without removing it and you don't need a programmer at all.
bye
« Last Edit: August 06, 2019, 12:39:59 am by pgo »
Offline fonak
« Reply #14 on: August 06, 2019, 05:50:51 pm »
Hi Microcheap and pgo
I did exactly (I use ch341a eeprom programmer) how you write in post from March 16, 2019, But this do not work for me.
As I wrote before, DSwiev sees the analyzer as Plus but after giving the rectangular signal to the iputs, softwere always sees zero (always flat line at zero level). When I return to original firmware everything worked fine as Basic version of course :)
I will try to upload the firmware again with your method and the method proposed by PGO. I hope one of them works. In addition, I will try to upload a hex downloaded from the Internet
Thank you pgo and Microcheap very much for your help
Offline fonak
« Reply #15 on: August 11, 2019, 01:16:16 pm »
I noticed a strange thing. When I ran the modified DSView file as pgo said (Offset EE9AC2, EE9B52 change  data from 21 to 20) the analyzer is detected as BASIC and works perfect as BASIC (buffer 163us @ 400MHz). Then without disconnecting the analyzer from usb I closed the modified DSView program and turned on the original one. Then the analyzer is recognized as PLUS and works perfect as PLUS version (167ms buffer @ 400MHz). If I disconnect the analyzer from the USB and connect again (or restart original DSView.exe ), the analyzer is recognized as a PLUS but does not see the rectangular signal at the input. The analyzer has been programmed with modified firmware (offset 00000003 and 0000186A change from 21 to 20).
« Last Edit: August 11, 2019, 01:20:00 pm by fonak »
Offline DEV001
« Reply #16 on: August 12, 2019, 10:50:48 pm »
After reading this thread, I ordered a USB programmer with SOIC-8 clip and a (MT48LC16M16A2) memory chip to upgrade my DSLogic basic. I will try the 'fx2lafw_eeprom_loader' tool first and if I can't get it to work I can desolder the flash chip if necessary. Hopefully the memory chip and programmer will arrive next week if the E-Bay estimates are accurate.
Offline excitedbox
« Reply #17 on: August 15, 2019, 09:47:46 pm »
I have a basic that isn´t upgraded yet. Where all would I have to change the memory value if I was gonna try the 512MB ram chip?
Offline fonak
« Reply #18 on: September 09, 2019, 07:29:53 pm »
Hello
New version of DSview has been released
change log 1.00 -- (2019-09-09)
  --common
  *add multi-language support and dynamic switch
  *add two themes (dark/light) support and dynamic switch
  *improve 4K/high DPI display support
  *add close function for file type device
  *add message tips when encounter file save errors
  *fix file format of export file, like VCD
  *fix other minor issues
  --for logic analyzer
  *add support for V3 version decode library
  *add more decoders, the number of decoders come up to 97
  *improve options and speed for certain decoders
  *fix load&store issue of some decode options
  *fix wrong measure result at certain sample rate
  *fix channel selection of stream mode
  *fix filter issue above 100M sample rate
  *fix decode error for long time capture
  *fix progress display issue when set region decode
  *improve measurement bwteent edges in different channels
  --for oscilloscope
  *improve the auto measure funciton, support up to 20 measurements
  *improve UI for auto measure
  *implement x-y mode display for lissajous-figure
  *implement Add/Sub/Mul/Div math channel
  *add horizontal measure cursors
  *improve measure of frequency, refer to current trigger level
  *fix captured wave display issue when change horizontal resolution
  *fix inconsistant issue when export csv file
  *improve algorithm of frequency measure, especially for low frequency and special signals
  *improve autoset function
  *improve auto calibraiton function
  --for data acquisiton
  *add default settings of Y-axis
https://www.dreamsourcelab.com/download/
Offline AngusBeef
« Reply #19 on: September 20, 2019, 10:28:28 pm »
I attempted to use the program but I don't have any compilers, and it won't run on Windows which it was compiled for without a pile of libraries. I'm attempting to use Eclipse and MINGW recompile it into a binary that includes all necessary libraries but it's a new experience for me. I would buy a programmer but this seems an interesting challenge.
Offline pgo
« Reply #20 on: September 21, 2019, 07:44:31 am »
Hi AngusBeef,
I believe the bin directory contains all the required DLLs from MingGW-64, the libusb DLL and the executable.
What DLLs do you believe is missing?
There should be no need to build anything (under Windows-64bit).
bye
Offline AngusBeef
« Reply #21 on: September 21, 2019, 08:01:28 am »
I know that libwinpthread-1.dll is missing from the directory (at least on my PC) as I get an exception for it saying it failed to start as it's missing that dependency.
However, once I downloaded the above .dll from MinGW and drop it in the bin folder I still get a different exception at 0xc000007b.
I'm solving a library linking issue with GCC and the Eclipse IDE on Linux since I'm getting the "function not defined" errors when I can see they're properly defined in the header files - but it's been about 8 years since I've played with C++ so I forgot almost everything and I'm on the struggle bus.
Edit: to clarify I have both a Windows computer and a Linux computer - tried running it on Windows and I'm trying to recompile it on Linux - the libraries you used are mostly cross-compatible with the exception of Windows.h which reading through looks like only was used for the sleep function - but there's unistd.h that provides the same.
« Last Edit: September 21, 2019, 08:05:25 am by AngusBeef »
Offline pgo
« Reply #22 on: September 21, 2019, 10:04:16 am »
Hi
I've added  libwinpthread-1.dll to the bin directory.
I didn't spot it missing as apparently there is a copy in my windows/system32 directory - presumably dropped by some other software.
I was assuming any DLLs picked up from there were part of windows.
It is probably important to have the correct version i.e. matching the build.
Dependency graph is attached.
I have also built it on Linux and included a binary  but this will be even more problematic.
bye
The following users thanked this post: AngusBeef
Offline AngusBeef
« Reply #23 on: September 21, 2019, 11:16:37 pm »
Thanks! Including the additional dependencies solved the issue running the software on Windows.
Connected the pins with two probes and a lead wire, read the hex file off, changed the appropriate entries, and voila - it's got a new PID.
The only issue I ran into was that the checksums were incorrect in my hex file the first time I tried to write it (because I changed values in two lines of course). - I'm glad you run those checks in your program - I did some reading and then updated the checksum for the two lines I changed and then it wrote with no issue.
I think your method is more ingenious and elegant than de-soldering the EEPROM to use a programmer - it takes advantage of the components that already exist on the board.
Offline dpenev
« Reply #24 on: November 10, 2019, 08:08:20 pm »
Hello,
I have one uinit from the very first DSLogic coming out of the Kikstarter campaign.
I was even helping in the RLE compression on this hardware few years ago.
I have not used my device much and now I saw people are upgrading the RAM and EEPROM so I thought let give a try
I have purchased MT48LC16M16A2P and and surprise, my unit is already with MT48LC16M16A2P :) so it seems the Kickstarter batch is with 256 Mbit out of the box.
DSview recognizes the unit as DSlogic.
I also noticed that DSLogic now seems to support RLE compression.
I know the Kickstarter batch does not support adjusting the threshold level.
Having all this in mind I have few questions:
1. Does it make sense to upgrade the EEPROM with the new PID, so eventually it is recognized as DSLogic plus?
2. Is there someone tested the procedure with an original Kikstarter unit?
    Is it working and what happens if one tries to adjust the threshold level?
3. Why people bother to upgrade the RAM at all?
    Does RLE compression work fine now?
    Does  DSlogic plus offer other benefits?
Thank you
Dimitar
Offline DavidA
« Reply #25 on: November 27, 2019, 01:25:23 am »
There seems to be an issue with AliExpress supply of MT48LC16M16A2P ICs at the moment - some feedback suggests that only the 133 MHz variant is being supplied even when the -6A 166 MHz part number is requested.
Is this an issue for upgrading the DSLogic Basic? Can it make effective use of the slower 133 MHz part? It looks like obtaining confidence in getting the exact -6A part is going to cost significantly more, if it's required.
Offline hhyytt
  • Country: cn
« Reply #26 on: November 29, 2019, 10:38:55 am »
I got a new DS Logic U2B, update sdram to 256Mbit, but modify the usb vid & pid to plus(u2b is 29, change to 20) in eeprom, but it can not work.
The PCB look like this.
Offline thm_w
« Reply #27 on: November 29, 2019, 10:31:21 pm »
Same here but have not received SDRAM yet. It came with 64Mbit(?) ram installed, so you removed that one and soldered the new one?
You may want to check some of those solder joints on the top under a microscope if you can.
Not working, as in after you changed the VID/PID in two places it no longer works at all or it still shows as a U2B?
Offline RoGeorge
« Reply #28 on: November 29, 2019, 10:51:51 pm »
I have a DSlogic and didn't use it in the last few years.  This months I tried it with the latest PulseView (Sigrok) which was already installed in Ubuntu, and DSLogic was not recognized.
Does the upgraded DSlogic works with a generic PulseView, too, or is it working only with DSView (which is nothing but a PulseView by DreamSourceLab)?
Offline thm_w
« Reply #29 on: November 30, 2019, 12:25:24 am »
Did you follow the installation procedure yet? https://sigrok.org/wiki/DreamSourceLab_DSLogic#Firmware
Offline hhyytt
  • Country: cn
« Reply #30 on: November 30, 2019, 04:08:30 am »
Yes, 64Mb -> 256Mb
Using U2B origin eeprom firmware, use buffer mode, test new SDRAM(256Mb) is ok.
Modify pid/vid, DSView shows Plus, but push start, only wait, not work.
I use other plus firmware from this post, DSView shows Plus, also not work.
Change DSView from latest 1.0.1 to 0.9.9, work ok. Because DSLogicPlus.bin changed, not work good with U2B version, you can copy older to latest 'res' folder.
« Last Edit: December 02, 2019, 07:21:36 am by hhyytt »
Offline RoGeorge
« Reply #31 on: November 30, 2019, 05:26:19 pm »
Took another look yesterday.  Turned out my DSlogic already has 256Mbit SDRAM, and it is not a clone, it was made by DreamSourceLab in 2015.  On the box is written DSLogic Pro.
[attach=2]
[attach=1]
When it is recognized, it appears as DSLogic Pro, so nothing to upgrade.  VID:PID of the device is 2a0e:0003, with no device description.
I don't recommend to use PulseView, try to use DSView instead.
DSView has way more acquisition modes, triggers and features than PulseView has, also DSView works properly, while PulseView sometimes returns fake signals or works erratically.  The easiest way would be to make a virtual machine with Windows 7 and install DSView in the virtual machine.
To run PulseView instead of DSview, it will need to install the DSlogic firmware files and to create a udev access rule.  Even after installing the firmware files and giving access to the device, PulseView / Sigrok will still have only a fraction of the DSView features and settings.  However, the latest PulseView might have some extra protocol decoders that were not yet ported to DSView.
However, if one insists to use PulseView in Linux:
1. Download PulseView from https://sigrok.org/wiki/Downloads
2. Make the downloaded AppImage file executable
3. Install the firmware files for DSlogic as described in https://sigrok.org/wiki/DreamSourceLab_DSLogic#Firmware
- download the firmware install script https://sigrok.org/gitweb/?p=sigrok-util.git;a=blob;f=firmware/dreamsourcelab-dslogic/sigrok-fwextract-dreamsourcelab-dslogic
- make the downloaded script executable and run it as root
sudo ./sigrok-fwextract-dreamsourcelab-dslogic
- by default the script will download the firmware files from github, then copy them into /usr/local/share/sigrok-firmware and from now on, any version of PulseView will find them when necessary
4. Make a new udev rule to grant access to the USB device, or else PulseView/Sigrok will throw the error "sr: dreamsourcelab-dslogic: Failed to open potential device with VID:PID 2a0e:0003"
- create a file named /etc/udev/rules.d/99-dslogic.rules with the following content
SUBSYSTEMS=="usb", ATTRS{idVendor}=="2a0e", ATTRS{idProduct}=="0003", MODE:="0666"this will grant access to the USB device with ID 2a0e:0003, which is the USB ID for my DSlogic Pro
- re-run all the udev rules, so the newly created rule file 99-dslogic.rules will be taken into account with the command
sudo udevadm control --reload-rules
5. Start the PulseView by running the AppImage file, and the DSlogic should now work.
./PulseView-NIGHTLY-x86_64.AppImage
6. After connecting to DSlogic, the LED will turn from orange to green.
« Last Edit: November 30, 2019, 06:03:13 pm by RoGeorge »
Offline DavidA
« Reply #32 on: December 01, 2019, 09:49:12 pm »
Has anyone successfully upgraded a DSLogic Basic with SDRAM IC MT48LC16M16A2P-75, -7D or -7E?
Offline hhyytt
  • Country: cn
« Reply #33 on: December 02, 2019, 01:54:32 am »
best is 6A. I bought  -75 first, after welded, not work.
Offline pgo
« Reply #34 on: December 02, 2019, 03:50:18 am »
The one I used was Element-14 (Farnel)
MT48LC16M16A2P-6A
bye
Offline thm_w
« Reply #35 on: December 08, 2019, 03:51:35 am »
Yes, 64Mb -> 256Mb
That works with DSView, thanks. I used the eeprom from fx2lafw_eeprom_loader linked above and its working with pulseview as well.
From what I can see the only difference between U2B and Pro is the memory chip. The board looks the same. But then why would they behave differently and have a quite different EEPROM loaded (see attached)?
Also of note, the cables may be improved over before but the Basic and Pro cables are still very different. You can see here the Plus cables have a heatshrink section, presumably for the shield of the coax:
https://www.aliexpress.com/i/32905798335.html
The Basic and U2B are just plain wires.
From the specs the adapter board and component values appear to be the same. So I may try in the future replicating their design with some RG178.
Offline BH3XON
  • Country: cn
« Reply #36 on: December 19, 2019, 02:58:33 pm »
Me too. Like the attachment, the PID becomes different. What can I do?
Offline thm_w
« Reply #37 on: December 19, 2019, 10:44:39 pm »
Did you try 0.9.9 dsview as recommended?
You can either modify the eeprom to change the PID to pro. Or you can simply re-flash with the Pro eeprom file that has been uploaded by pgo.
Offline BH3XON
  • Country: cn
« Reply #38 on: December 20, 2019, 12:40:55 am »
so,you mean using the old version of dsview, I try, thanks!
btw, new version has two UIs,i like this
Offline thm_w
« Reply #39 on: December 20, 2019, 01:30:26 am »
You can either use the old version, or copy the 'res' folder from 0.9.9 to the new version, as hhyytt has discovered above.
Offline BH3XON
  • Country: cn
« Reply #40 on: December 20, 2019, 03:15:36 am »
Great!  I try,thank you reply!
Offline BH3XON
  • Country: cn
« Reply #41 on: December 20, 2019, 06:12:49 am »
I tried the method of hyyytt, covering the res of 1.0.1 with the 0.9.9 version of the res file.
but, opening 1.0.1 is still recognized as the u2b version。
my modification:
1. 64M --》 256M;
2.EEPROM  edit PID;
3.DSVIEW 0.9.9  res  replace--》 1.0.1 res
   File from  https://github.com/miniwave/DSview_v0.99
4.open DSVIEW 1.0.1   Identified as U2B     fail!
Attached is the HEX file after modifying the PID
 tell me what is wrong?
Offline Enginerding
« Reply #42 on: December 28, 2019, 03:24:23 am »
Can the U2Basic be upgraded to the same specs as the Pro, just like the previous Basic?
I got sent a U2B from Aliexpress w/ out the shielded fly wires, instead of the Basic.  Poop.  Filed a claim and got offered to ship it back (>$20) or take a 50% refund.  7 days to appeal.  I can buy the fly wires separate for $~25.
Meters: Keithley 196, 181.  HP 3457a, 4274a LCR.  References: MV106g, EDC 501j.  Scopes: LeCroy LC574AL/LC584AL 1GHz, 9354C.  And of course the ubiquitous 1054z.  Former Army Medic -- IQ x3.
Offline Crazy_Fox
  • Country: ua
« Reply #43 on: January 02, 2020, 01:13:05 pm »
Got the crappy DSLogic U2Basic
There are at least absent PCB trace from FPGA to RAM chip, so according to the MT48LC16M16A2 datasheet A12 pin (last pin of address bus) is not connected, so at least 16x16 DRAMs cannot be addressed fully.
Seems we can add some wire with the same length as another traces for address bus, but I'm not sure that this is the only change in the PCB design.
[attach=1]
The following users thanked this post: egonotto, thm_w, ceres-c
Offline Crazy_Fox
  • Country: ua
« Reply #44 on: January 04, 2020, 02:54:30 pm »
Hi, Team
As my 256Mb chip still in transit, I decided to play a little with EEPROM.
I'm pretty lazy, so decided to connect 4th and 7th pins with small wire instead of desoldering EEPROM chip. But unfortunately, fx2lafw_eeprom_loader.exe unable to find my U2Basic due to 0029 PID, so I've modified .exe file to enable support U2Basic instead of Basic (just replaced 21 to 29 in offset 0x00008472).
After that I was able to load Basic firmware to the U2Basic and now it works as old good DSLogic Basic (with 400MHz sample rate and 256Kb buffer).
If you are interested in - feel free to use it. In the archive - fx2lafw_eeprom_loader with 0029 PID instead of 0021, .hex dump of DSLogic U2Basic EEPROM, and .hex dump of DSLogic Basic EEPROM.
Offline Mrkvak
  • Country: cz
« Reply #45 on: January 06, 2020, 02:10:45 am »
Are you able to verify it actually works above 100MHz?
I've just changed the source code of DSView: libsigrok4DSL/hardware/DSL/dsl.h, added | (1 << DSL_BUFFER200x8) | (1 << DSL_BUFFER400x4), after (1 << DSL_BUFFER100x16) and changed samplerates100 to samplerates400 in DSLogic U2B definition (around line 532).
Now it seems to work up to 400MHz with 64MB buffer, but I have no way of verifying that since I don't have a working generator above 100MHz.
Offline RoGeorge
« Reply #46 on: January 06, 2020, 02:14:21 am »
Use the generator at 100 MHz, and should see about 4 samples for each period of signal.
Offline Mrkvak
  • Country: cz
« Reply #47 on: January 06, 2020, 07:28:18 pm »
Well, it shows 40 samples for 10MHz signal. So I guess this part works - however, the question is whether it will really work at 400MHz or if it'll do just some weird interpolation or something like that.
I have my doubts about DSL (whichever version) working reliably with 100MHz+ signal anyways...
Offline DrTune
« Reply #48 on: January 07, 2020, 07:57:09 am »
My experiences:
a) Bought U2 Basic.
b) Opened it up, wires pin 4 to 7 on the SPI flash
c) Reflashed with the "Basic" hex using the modified fx2lafw_eeprom_loader_u2b.exe  - replugged, works (with current latest DSView 1.0.1) recognized as Basic model that does 400Mhz (appears to work fine, but obviously no real buffer memory)
d) Replaced SDRam with 48LC16M16A2-75 (hot air and microscope. I think I did it ok, we shall see..)
e) Booted again (still as 'Basic'), still works (as it's ignoring the SDRam)
f) Flashed this "Basic" version with https://raw.githubusercontent.com/podonoghue/LogicAnalyser/master/Software/fx2lafw_eeprom_loader/bin/DsLogicPro hex file using the 'unmodified' fx2lafw_eeprom_loader.exe
g) DSView 1.0.1 recognizs it as DSLogic Plus, but hangs ("waiting for trigger") when capture starts
h) DSView 0.9.9 does work:  Streaming mode: works but oddly I see periodic one-sample zero glitches (e.g. every 16 samples are zero) on all channels. Self-test doesn't even work right. Ack. Stuff is all half-broken, lots of bad samples and stuff. Dammit.
i) Put board back under microscope and redid the SDRam soldering, it wasn't a great job the first time
j) Plug it back in and... lots of it works! (on V0.9.9) I fed in a 25mhz clock to the first four channels and sampled it at 400mhz (buffered mode) and it's fine!
e.g.
j1) Buffered mode, 4 channel, 400mhz sampling, with 167.77ms buffer (max available; not using RLE) == 400M*0.5*0.167 = 32MBytes = 256MBit.  The data (25mhz clock on all channels) looks great.  Adjustable input voltage threshold is working too.
j2) NOTE: RLE modes do _not_ seem to work reliably for me at >100Mhz speeds:
    8 CH @ 100mhz, 200ms RLE sampling works ok, but stepping same thing to 200mhz gets me garbled results, channels shifted around, general half-crap.
    However, if I do the same 8CH/200mhz buffered without RLE, the data (superficially) looks good.
So.. almost fully working...
The RLE crapping out at 200Mhz and up may imply sporadic SDRam errors (that are perhaps returning a few wrong samples not visible to the eye in non-RLE mode; obvs errors in RLE would cause large ripple effects on the data, like what I'm seeing)
This may well be memory access time problems (I am using a -75 chip).
I may swap the SDRam for a faster one, or just not use RLE modes on this and treat it with a bit of suspicion over 100mhz.
V1.0.1. note:
You can (kinda) use this with 1.0.1 software too - you just have to use the bitstreams from 0.9.9 (as pointed out on here);
in the "DSView/res" folder you can replace the "DSLogicPlus.bin" xilinx bitstream file with the one from 0.9.9
(Note that the firmware is only loaded if the device has not been programmed since it was plugged in, so you can (for example) run v0.9.9, do a capture, then quit and run V1.0.1)
I assume the 1.0.1 bitstream is superior, but it hangs on start on a hacked unit. Pehaps my RLE errors are actually something they fixed in the new bitstream.. ? More likely they are that my SDRam is too slow. We shall see...
The following users thanked this post: thm_w, tlun
Offline thm_w
« Reply #49 on: February 16, 2020, 06:10:59 am »
Thanks, this seems to be working well. Made a small attempt at trace length matching.
edit: the 1.0.1 bitstream is working as well.
« Last Edit: February 16, 2020, 06:16:43 am by thm_w »
The following users thanked this post: DrTune, ceres-c, Crazy_Fox
Offline fonak
« Reply #50 on: February 25, 2020, 03:25:22 pm »
Hello,
A new version of DSView 10.1 has appeared
link:
Changelogs:
–common
*add support for DSCope U3P100 device (100M bandwidth/1G samplerate/USB3.0 oscilloscope)
*add support for DSLogic U3Pro32 device (32 channels/1G samplerate/USB3.0 logic analyzer)
*add support for DSCope U2B100 device (100M bandwidth/1G samplerate/USB2.0 oscilloscope)
*add support for DSLogic U3Pro16 device (16 channels/1G samplerate/USB3.0 logic analyzer)
*add display of device type (USB 2.0 / USB 3.0 / Demo / File)
*add version check for FPGA firmware
*improve the default file name when saving/exporting files
*fix other display and language issue
–for logic analyzer
*extend channel support for trigger up to 32 channels
*fix issue of ps/2 decoder (#239)
*fix issue of cec decoder (#235)
*fix ID issue when export results of decoder (#237)
*fix “not” logic don’t work in advance trigger
*fix other display issues
–for oscilloscope
*improve wave shake issue when trig high freqency signals
*fix sampling point selection issue of downsampling
*add 20M bandwidth limitation for DSCope U2B100 / DSCope U3P100 devices
*improve synchronism between data acquisition and wave dispaly
*fix wave display and measurement issue when change vdiv and offset after stop
*fix capture restart issue when change offset in roll mode
*fix issue of timebase of math channel can’t be changed when waiting trigger
*fix issue of offset can’t be changed when waiting trigger
*fix clear and flicker issue of auto measurements
*fix cursor and mouse measurements issue after change samplerate when waiting trigger
*fix trigger issue when toggle between different trigger source
–for data acquisiton
*fix hardware offset setting issue
*fix mipmap issue of long time data at some case
*add cursor and mouse measurements
The following users thanked this post: thm_w, RoGeorge
Offline ceres-c
« Reply #51 on: March 07, 2020, 08:34:12 pm »
I've made the same modification, but it's still not working with the latest bitstream.
Maybe it's due to the RAM I'm using, given I have soldered the -75, which is 34MHz slower than the -6A version. Which one of the two do you have?
Offline masterx81
« Reply #52 on: March 08, 2020, 12:55:33 am »
The u2b that i've upgraded had a 166mhz memory, replaced with a 6e variant and all ok. So i think that the 133mhz version can have problems
Offline ceres-c
« Reply #53 on: March 08, 2020, 08:02:09 pm »
Thanks @masterx81, probably my intuition was right then.
But could you please confirm you're talking about the 6A version? I could not find any 6E, while there is a 7E, which is 133MHz as well, which would probably be too slow as well.
Or maybe it was me who couldn't find it
« Last Edit: March 08, 2020, 10:16:29 pm by ceres-c »
Offline masterx81
« Reply #54 on: March 08, 2020, 10:00:26 pm »
6A, not 6E, you are right  :-+
The following users thanked this post: ceres-c
Offline thm_w
« Reply #55 on: March 10, 2020, 12:50:45 am »
In the photo I posted above, -6A
Offline kivijakola
« Reply #56 on: March 29, 2020, 09:15:20 am »
I received also my DSLogic Basic  that has 64 Mb ram installed. I did some investigations to upgrade to pro and noticed following:
64Mbit ram datasheet can be found from here:
https://www.winbond.com/resource-files/w9864g6kh_a02.pdf
And 256Mbit version here:
https://www.winbond.com/resource-files/da00-w9825g6khc1.pdf
Difference between those is that 256Mb version has extra address pin A12 mapped to pin 36. Measured that pin from PCB and seems that it is not connected to any pin of Spartan? Has anyone measured that from Pro version where that should be connected?
Offline kivijakola
« Reply #57 on: March 29, 2020, 09:27:18 am »
Found one blurry image of back side of pcb from net. Seems that there is at least on trace missing from my basic version compared to that.[attachimg=1]
Offline masterx81
« Reply #58 on: March 29, 2020, 09:27:52 am »
Look here for u2b;
https://www.google.com/amp/s/m.habr.com/ru/amp/post/483496/
I've used a thin enameled wire to connect the missing addressing pin. The i've done the eeprom mod and it works perfectly
The following users thanked this post: kivijakola
Offline eetechTom
« Reply #59 on: April 01, 2020, 03:49:39 pm »
I have a question regarding the shielded leads w/compensation network. The only 2 suppliers that seem to show these with the DSLogic Plus are Banggood, and Dreamsource.
Thanks.
Offline eetechTom
« Reply #60 on: April 01, 2020, 04:00:45 pm »
I see thm_w's post helped answer this a few months ago. :clap:
Offline masterx81
« Reply #61 on: April 01, 2020, 04:45:17 pm »
So the difference from this 2 types of leads?
Offline eetechTom
« Reply #62 on: April 01, 2020, 05:09:52 pm »
Yes masterx81, that's correct. I see aliexpress does sell the DSLogic Plus with the upgraded leads.
I need to order a large quantity for our engineering students, which might be a big ask.
Offline eetechTom
« Reply #63 on: April 01, 2020, 05:27:41 pm »
More digging shows that one aliexpress supplier does have a massive amount of stock (4000+). Price is good at $95 US.
Offline masterx81
« Reply #64 on: April 01, 2020, 06:08:32 pm »
Sorry but what's the difference between the two type of leads? Less noise at high frequency?
Offline thm_w
« Reply #65 on: April 01, 2020, 09:26:05 pm »
Yeah shielding could help a bit with noise. Bandwidth should be higher with the coax. But no one has actually compared the two.
Offline masterx81
« Reply #66 on: April 01, 2020, 10:31:11 pm »
I have one of the "older" leads, but also this seem a really small coax cable, connected to ground on the unit side
Offline RoGeorge
« Reply #67 on: April 01, 2020, 11:16:54 pm »
Any cable is also a transmission line.  In a transmission line, when the impedance is not matched, the signal is reflected back and forth, making one see spikes or ringing on the signal edges if it is observed with an oscilloscope, or fake/multiple edges instead of only the correct edge when looking with a signal analyzer that can see only zeroes and ones.
Note that this reflections happens no matter how low is the frequency of the signal.  What matters most in case of digital circuits is the raising and falling time of the edges.  The fastest the edge, the more problems, no matter if we look at a 100 Hz or a 100 MHz signal.
TL;DR
The shielded cable is supposed to:
- have a controlled impedance, so one can match the impedance, and thus observe the correct signals and correct edges, not influenced by signal reflections.
- have a controlled velocity factor (and thus an equal propagation delay for all wires), so the edges from many parallel lines are observed in the correct order.
With normal (unshielded) wires, the impedance varies wildly, depending how the wire is bent or twisted, or how close is relative to other wires, or relative to GND.
This video from w2aew explains very well the idea of transmission lines and reflections, and also shows the waveform produced by the combination between the original signal and its reflections.  Keep in mind that the same phenomena happens at any frequency, no matter if it's sinusoidal signal for a radio transmitter, or square signal for a digital circuit.  The signal analyzer will be very confused by the strange waveforms appearing because of reflections.  Also, keep in mind that those reflections seen in the video are nice and stable only because the pulses duration is constant.  With varying digital signals, the combination between original and reflected signal can turn even the cleanest waveform into an unrecognizable mess.  So, here is why, and how it looks like for the most simple cases:
Now, how worry should we be?  For looking at signals on an Arduino or a breadboard, using short wires like the ones coming with the probes, most probably there will be no visible difference between a shielded cable and a normal wire.
For looking at high speed signals with very aggressive edges, on a PCB with controlled impedance traces, the shielded cable and correct impedance matching is a must.
As an example, if you put a clean square wave (no matter the frequency, but with very fast edges), and don't care about the impedance matching, you can easily see 2-3 fake edges instead of one, especially at maximum acquisition speed.
By fake edge, I mean a few very close transition instead of a single clean falling or clean raising edge.  Looks similar with a debounce noise, but it is caused by signal reflections, not by imperfect mechanical contacts.
As a fun exercise, you can see how the number and the distance between the oscillations of a fake edge varies with the length of the connection wire, or with the impedance mismatch.  ;D
Offline rfdes
« Reply #68 on: May 15, 2020, 01:14:14 am »
Look here for u2b;
My effort to upgrade my U2 Basic to Plus went poorly.  Unless this is not understood, the FPGA pin that drives the A12 Ram pin is connected to GND on the U2Basic PCB.  The above link shows that this pin needs to be isolated by carefully 'lifting' the pin from the GND pad.  I struggled but managed to get this pin lifted and made the connection to the RAM A12 input.  However, the mod failed.  I believe that I may have damaged this FPGA pin by updating the EEprom to PLUS and applying power to the board 'before' I isolated the FPGA pin from GND.  My belief is that with the board configured as a PLUS version, this forced the FPGA pin to an OUTPUT while it was connected to GND, causing a short circuit and damaging this FPGA pin.  I have no proof of this but I recommend isolating the FPGA pin before configuring EEprom to the PLUS version.  At this point when I perform an internal test, the test shows all 0 on each line.
Does anyone have any further information regarding this?  Curious if others had similar failures.
Take care -
rfdes
Offline thm_w
« Reply #69 on: May 15, 2020, 08:50:36 pm »
The pin should be not connected on both sides, then you add a jumper wire to connect fpga to ram.
It shouldn't be grounded. But I can't remember actually measuring to confirm that.
You can see my photo above: https://www.eevblog.com/forum/testgear/upgrading-dslogic-basic-to-plus-without-eeprom-modification/msg2921384/#msg2921384
Internal test worked OK.
« Last Edit: May 15, 2020, 08:54:21 pm by thm_w »
Offline rfdes
« Reply #70 on: May 15, 2020, 10:45:54 pm »
I've seen the bare PCB without the FPGA installed and the I/O pin used to drive A12 is definitely grounded.  My issue was resolved due to an intermittent solder bridge on the FPGA between two signals used to read/write to the RAM chip.  These two pins are located about 10 pins away from the i/o signal used to drive A12.  It was just a coincidence that this started giving me trouble at the time I was implementing the upgrade modification.  Just my luck.  Anyway after clearing the bridge all is well.
take care -
Offline thm_w
« Reply #71 on: May 24, 2020, 09:47:23 pm »
take care -
Thank you for noticing :-+, took it apart again and it was grounded as you say. Have to lift the pin using a pointy exacto knife.
From what you are saying self-test should indicate failures in memory, but maybe I wasn't looking closely or its not fully testing the memory capacity, as I don't remember seeing anything unusual there.
Offline robca
« Reply #72 on: August 21, 2020, 11:29:06 pm »
Has anyone found a good source to buy just the shielded cables like the Plus uses? I'm upgrading my U2Basic (thanks to everyone who contributed to this thread) and the only source seems to be https://www.aliexpress.com/item/32999482818.html, for around $30 shipped to the USA
Not sure if it's worth the extra cost, though, so I'll start with the memory upgrade only (and using fx2lafw_eeprom_loader to change the device ID) and see if it works well enough for me at the relatively low speeds I'm likely to use
