Author Topic: US$150 Class Multimeter  (Read 19912 times)
Offline coromonadalix
Re: US$150 Class Multimeter
« Reply #75 on: May 01, 2020, 12:26:46 am »
121gw  lite ??
Offline maginnovision
« Reply #76 on: May 01, 2020, 01:12:20 am »
It's supposed to be a more durable meter than the 121gw. So I'd call it a 121gw X-Plus ala siglent.
Offline EEVblog
« Reply #77 on: May 01, 2020, 01:23:22 am »
Actually that's an interesting point.
Certainly more rugged from an electrical point of view, but from a mechanical point of view, I don't know. The 121GW is a full holster based meter, this one is an overmoulded split case design. Similar to say a Fluke 77 IV
Of course the 77 IV is stupidly rugged, so it's not a matter of just having lack of a thick holster. It feels pretty rugged.
Now that I think about it, yeah, it's kind a competitor to the Fluke 77 IV in terms of look'n'feel of the overmoulded case, no fuse access via battery compartment, but with extra stuff like EF testing, 60,000 count, proper low current support, way better specs etc. i.e. a proper "electronics" version of a Fluke 77 IV.
« Last Edit: May 01, 2020, 01:31:29 am by EEVblog »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #78 on: May 01, 2020, 01:31:20 am »
Great suspense, Dave!
A split case is less desirable from my point of view, but a recently acquired Amprobe is quite well done and fells really robust.
Offline EEVblog
« Reply #79 on: May 01, 2020, 01:32:30 am »
Great suspense, Dave! A split case is less desirable from my point of view, but a recently acquired Amprobe is quite well done and fells really robust.
Yeah, I didn't know it was split case fuses inside until I got it. The early photos were just from the front were you can't tell.
Offline EEVblog
« Reply #80 on: May 01, 2020, 01:53:15 am »
And it's got a custom hybrid resistor divider too, wasn't expecting that for the price, but I guess it's the only way they could get the fairly tight spec.
« Reply #81 on: May 01, 2020, 02:24:41 am »
Dave i'm having a nervous breakdown from waiting  loll
Can the design be changed in the future for the fuses access,  meaning like a huge battery door and fuses change without opening the meter each time ?
Or Its an almost or "in production" model ?
Offline EEVblog
« Reply #82 on: May 01, 2020, 02:26:40 am »
Nope, it's done, it's passed UL and other testing. This is what will ship.
Offline EEVblog
« Reply #83 on: May 01, 2020, 02:35:32 am »
- Jack alert doesn't work, but it's supposed to have it.
Idiot Dave forgot to install the fuses after reassembly  :palm:
The following users thanked this post: jancumps, JustSquareEnough
« Reply #84 on: May 01, 2020, 03:15:02 am »
I can see why some people don't like the lack of fuse access but it definitely doesn't bother me. I actually prefer the overmould design as opposed to a holster as well in virtually every meter I've owned. Looking forward to seeing it.
Offline Monkeh
« Reply #85 on: May 01, 2020, 03:21:56 am »
Hard to get at and expensive fuses are just motivation not to be an idiot and blow them.
Offline ahbushnell
« Reply #86 on: May 01, 2020, 04:11:44 am »
In case you haven't figured it out, I fishing to see if it's worthwhile stocking a US$150 class meter in addition to my $100 class BM235 and $200 class 121GW.
I paid 135 + CA tax for the EEVblog Brymen BM235 Multimeter on amazon a few months ago.
Great meter.  I notice it's not available now.
Offline EEVblog
« Reply #87 on: May 01, 2020, 04:13:03 am »
Just got new stock in yesterday, need to ship more to the Amazon mothership.
Offline EEVblog
« Reply #88 on: May 01, 2020, 08:22:15 am »
[attachimg=1]
Offline Brumby
« Reply #89 on: May 01, 2020, 08:54:44 am »
Sounds like something I'd do.    ;D
Offline evava
  • Country: cz
« Reply #90 on: May 01, 2020, 09:13:59 am »
Is there a reason why wait on this meter instead of buying Brymen 857s ?
Can this be more bang for the buck?
Offline EEVblog
« Reply #91 on: May 01, 2020, 09:25:35 am »
Depends what you need. The 857S is based on a really old design, but it's got 500,000 count mode and PC interface. This new meter has EF detection, visual continuity, almost certainly more modern front protection and higher 60,000 count in normal mode. Maybe other things I haven't done a full comparison.
The following users thanked this post: Marco1971
Offline Muttley Snickers
« Reply #92 on: May 01, 2020, 10:12:17 am »
I couldn't wait any longer so am going to go with the one in the video below, a comprehensive teardown and re-assembly is also included. A few of the special features it incorporates are visual continuity display, ac voltage indication, fuse free operation, one second auto power off and an automatic natural selection mode.   :-DMM :o ::)
https://youtu.be/YEfiyPFWVdg
The following users thanked this post: oPossum, rsjsouza, exe, joeqsmith, Gregg, 2N3055, Electro Detective, BillB, Kosmic, umbro, Corner
Offline 2N3055
  • Country: hr
« Reply #93 on: May 01, 2020, 11:20:37 am »
[attachimg=1]
Well that resistor divider being stuck to the board kinda defies the purpose of that quite nice separation distance..  That is not going to help with breakdown voltage...
But it might not be a problem if input clamps keep it at safe voltage..
Offline EEVblog
« Reply #94 on: May 01, 2020, 01:06:41 pm »
[attachimg=1]
Not at all. You still have the PCB creepage, no difference in distance, and it's not stuck down, just bent over.
That's the job of a clamp.
« Last Edit: May 01, 2020, 01:10:16 pm by EEVblog »
Offline 2N3055
  • Country: hr
« Reply #95 on: May 01, 2020, 01:26:16 pm »
[attachimg=1]
Thanks for clarification, on photo it looks to be down on board, at the level of that screw head, touching it...
But that is all just talk. If it works it works..
Regards,
Sinisa
Offline EEVblog
« Reply #96 on: May 01, 2020, 02:46:59 pm »
Even if it was flat on the PCB touching for the entire surface it wouldn't make a difference, the creepage distance is the same length along the PCB anyway.
Offline 2N3055
  • Country: hr
« Reply #97 on: May 01, 2020, 02:52:50 pm »
That's debatable, if you look, at half of resistor creepage distance there is ground underneath the resistor. So looking at that, that is definitely half of what is resistor rated for... But still, what is left is a lot, and if something discharges it will go to ground, not to input.
Like I said, looks funny, but probably not an issue...
Thanks for nice discussion.
Offline rsjsouza
  • Eternally curious
« Reply #98 on: May 01, 2020, 03:28:14 pm »
Yes... Darwin natural selection when plugged to that 1kW power supply!  :-DD
The use and abuse of hot melt glue is something that bothers me - when I was a young padawan doing these projects with my dad in the 80's, he taught me to properly cut your panels and attach all the mounts obeying their specifications. I somehow can't help but wonder that he would slap me in the head if I came up with something this ugly.  :scared:
Offline joeqsmith
« Reply #99 on: May 01, 2020, 05:34:51 pm »
Best post so far!
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
