Author Topic: USB logic analyzer - what's the current "favorite" for ~150$? Hantek 4032L?  (Read 18643 times)
Offline TK
Re: USB logic analyzer - what's the current "favorite" for ~150$? Hantek 4032L?
« Reply #50 on: December 27, 2019, 01:58:31 pm »
The DSLogic Pro has a 400MHz sample rate, so you should be able a 50MHz SPI signal
Offline lfldp
« Reply #51 on: December 27, 2019, 09:04:04 pm »
but sample rate is sample rate and maximum input bandwitch is another case
i think this limitation 50mhz in old dslogic version causes this problems
Offline TK
« Reply #52 on: December 27, 2019, 09:16:44 pm »
Isn't bandwidth measured on each channel?
Online thm_w
  • Non-expert
« Reply #53 on: December 27, 2019, 10:54:41 pm »
There are some other threads and the sigrok wiki where the differences are discussed.
Things which might matter for performance:
- Probes, do they have internal compensation circuitry
- Is probe wire coax or plain wire
- Internal components forming termination on the board, circuitry may have changed on the newer models?
If you have a decent scope it might give you some clues when probing.
The oldest model uses 0.1" headers:
https://sigrok.org/wiki/DreamSourceLab_DSLogic_Plus
https://sigrok.org/wiki/DreamSourceLab_DSLogic_Pro
Offline lfldp
« Reply #54 on: December 28, 2019, 12:43:45 am »
thats right thanks
i have a shorts in original cable perhaps sticker makes this shorts
after removed this sticker and cleaned connector i gets correct log
btw. where i can buy good quality dslogic connector without shorts which will fit to older version which i have ?
Online thm_w
  • Non-expert
« Reply #55 on: December 28, 2019, 01:21:45 am »
I'm not aware of any sources. You could ask the aliexpress sellers or directly.
At some point I was thinking of making the PCB's myself and then running some 1.13mm coax for cabling (https://www.aliexpress.com/item/32973720198.html or similar).
Offline daro19862
Which has have better parametrs:?
-Hantek 4032L?
-LA5016
