Products => Test Equipment => Topic started by: Peter Gamma on September 17, 2020, 11:47:50 am
When I use two Muse 1 headbands with Bluetooth simultaneously and connect them via Bluetooth to a PC trough LSL. Can I solve the Bluetooth bandwidth problem by adding more Bluetooth dongles to the PC? Can I increase the bandwidth in this way to connect as many Muse headbands as I want simultaneously to a PC?
Unfortunately not:
https://forums.pureinfotech.com/t/can-i-use-more-than-one-bluetooth-adapter-on-the-same-computer/445
this is a pity. How can more Bluetooth bandwith be obtained?
Is there no workaround to have more than one Bluetooth dongle connected to a PC and bring them to work?
There is a module on Aliexpress which can connect an TGAM EEG module over Bluetooth to Android or to a PC:
https://de.aliexpress.com/item/32606318948.html?spm=a2g0o.productlist.0.0.f9b614c9tGnEVN&s=p&ad_pvid=2020091704483611901111904167900000185215_1&algo_pvid=297f759d-6c2c-4efa-9a02-f8f6b6602b3d&algo_expid=297f759d-6c2c-4efa-9a02-f8f6b6602b3d-0&btsid=0ab6d59516003433164674831ed84d&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
The manufacturer can deliver SDKs for Android and connect the device over BlueSoleil to a PC. The description says.
"with this kit you can make a wear BCI device yourself"
You can build your own Muse headband with this kit with as many EEG channels as you want. This might be interesting for EEG software developers. But due to bandwidth limitation only four about 4 channels.
I suppose if someone develops special software for it, then it would work.
Windows allows only one sound card. But it is possible to add multiple usb sound cards to a PC. But only one works.
A solution for adding as many EEG sensors as you want is by connecting them through Scott Hardens sound card device:
https://swharden.com/blog/2019-03-15-sound-card-ecg-with-ad8232/ (https://swharden.com/blog/2019-03-15-sound-card-ecg-with-ad8232/)
and replace the ECG sensor by an EEG sensor. Scott Harden, has developed special software for his device which can handle with multiple sound cards.
The Aliexpress seller of the Blueotooth EEG sensor answered the questions about multiple Bluetooth dongles:
"Actually it can be available, just need to modify the pairing code of each donge"
Or eventually Bluetooth dongles from different manufacturers.
Answer from Aliexpress seller: "Maybe it works, I'm not sure".
But does it make sense at all? EEG devices with more channels usually use wifi. Would there be a reduction in energy consumption with multiple Bluetooth sticks in parallel compared to wifi?
