It was very late last night so I only got to test with nothing on the inputs, so no modulation, but lots of noise. I did notice in Dave's video he seemed to be able to turn the "entire" brightness way down, where I was not able to see any difference when making the same adjustment with no input. Perhaps there were setting differences as you mention. I guess my question is if there are certain settings / conditions were the intensity / brightness adjust appears to have no effect? Shouldn't I have seen a change with about 6 mv of noise?
Here's Dave's video I was referring to. Go to 11:30 in the video to see the intensity adjustment
We both have open inputs, and min persistence, and his intensity adjustment makes a huge difference, were I see no difference at all when adjusting. My brightness does not change? Unless there is another setting difference I don't really understand why I don't get the same result?
Dave, Have you seen this thread? Comments?
Just trying to rule out a possible defect on a new scope to make sure a return in not in order.
