Anyone have experience with both the 8560E (or other same series models) and the Agilent E4400 Series (E4403, E4402B, etc.), or have any insights/thoughts on how the 856XE compares to the E44XXB? The specs might be better on the 856XE but the user interface might be better on the E44XXB? (I noticed in a couple of videos it looks like w2aew uses a E4411B.)
At work we have dozens of lab grade analysers and we also have some of the E4407 type analysers. These don't offer the same RF performance as the HP856xE analysers but they do have a more modern user interface and a fresher looking display.
The E4407 analysers we have at work have an optional self cal routine that makes an annoying cheepy/chirpy noise each time it runs. A bit like there is a small hatchling bird inside singing for food when it gets hungry every few minutes. You can't hear it in a big noisy lab but in a small room it is very noticeable and I find it very distracting
It can be turned off in the menus after it has warmed up but this is at the risk of losing some accuracy over time.
The E4407 is also a very good looking and nicely built analyser and it is quite easy to move around (not that heavy) and has very chunky rubber support blocks around its extremities giving it a reasurringly robust feel.
They tend to get used for field trial work or for basic verification tests. Especially by people doing basic system testing or faultfinding. But for serious RF design work the HP856xE analysers are much better in terms of the raw RF performance. eg noise and spurious performance and overall measurement uncertainty.
But top dog at work are the E444x PSA analysers and we also have a few PXA analysers although some of these may be rented. I'm assuming that you aren't including the E444x in your list as these are very expensive. I'd like to have one here at home but can't justify the cost of a used one
