Author Topic: Used test equipment sources in UK (surge generator)  (Read 916 times)
Offline Mark
« on: April 30, 2015, 02:48:36 pm »
Hello all,
I am looking to purchase a used surge generator with the following specs.  Can anyone suggest a source for this in the UK?
1.2/50us open circuit voltage, 8/20us short circuit current.
Adjustable from a few hundred volts to 6KV peak.
Output Z <= 12 ohm (2 ohm Z would be nice).
Output polarity settable to + or -.
Manual control is fine.  No need for programmability or remote control.
Only single output is needed.  No need for Mains coupling.
No need to be certified for any particular industry or government Standard.
Thank you!
Offline JackP
    • TextGear
Re: Used test equipment sources in UK (surge generator)
« Reply #1 on: April 30, 2015, 03:05:13 pm »
There are various surplus stores around the UK, where you might find it. Google "surplus electronics test equipment UK" or something to that effect (I found at least five major ones).
Want to know more about 'scopes? Click here to check out my Oscilloscope Basics eBook series.
