I picked up my new scope today and thought it was a good time to break out the programming manual.
I did some tests feeding the trigger out of the DS2072 into the external trigger and channel 1 of the DS1052, and got a trigger delay of 210ns +/- 5ns across all time bases on both scopes. So I though that wasn't too bad, the trigger delay could be corrected for, so it just leaves the uncertainty over +/-5ns.
So I learn't a few SCPI commands (I never realised it was as easy as it is,) and hacked together a quick piece of test software to see if the concept was going to work. I recon it worked ok, and it'll be easy enough to write an SPI decoder for it. The screen shot attached was using a 200kHz SPI bus that's driving a DAC. Both 2nd channels of the two scopes are capturing the same clock signal to show the channel alignment.
