Author Topic: using 3x CR2032 to power a fluke 77 series meter  (Read 2985 times)
Offline robert.rozeeTopic starter
« on: October 19, 2023, 12:44:56 pm »
i was thinking... how practical would it be to power a fluke 77 (or similar) from a stack of 3x CR2032 cells?
1. a stack of 3 would easily fit within the volume of a PP3 battery. indeed, two stacks of 3 would fit along with a couple of schottky diodes and terminal clips;
2. the capacity of a CR2032 is around 250mA/h 250mA.h, versus something like 500mA/h 500mA.h for a PP3;
3. the battery housing could be 3d printed, or made out of a stack of PCB material, or consist of a single PCB with metal holder clips (2 on top, 1 underneath);
4. CR2032 cells are really cheap.
i just did a quick test, with a stack of 3x CR2032 cells totalling 9.3 volts and having no trouble supplying the 500uA or so needed.
an interesting idea?
cheers,
rob   :-)
« Last Edit: October 19, 2023, 01:06:04 pm by robert.rozee »
The following users thanked this post: BILLPOD
Offline wasedadoc
Re: using 3x CR2032 to power a fluke 77 series meter
« Reply #1 on: October 19, 2023, 12:55:18 pm »
Minor correction.  Capacity is current multiplied by time.  Hence you should be writing mAh, not mA/h
The following users thanked this post: robert.rozee
Online Fungus
« Reply #2 on: October 19, 2023, 01:07:52 pm »
I'm sure it'll work but what would be the point?
Offline Ian.M
« Reply #3 on: October 19, 2023, 01:13:21 pm »
The Energiser datasheets I have seen differ from your numbers.  Their Alkaline PP3 is about 600 mAH capacity but their CR2032 'falls off the cliff' with rapidly rising internal resistance around 200mAH.  I doubt no-name or off-brand CR2032's will be any better.
For the same life you'd need 9 cells, and there's only room for 6 so you'll be changing them more frequently.  The only benefit is the reduced risk of leakage, which is pretty low anyway for a branded alkaline PP3, and can mitigated by wrapping the battery in clingfilm after fitting the clip, reducing the potential damage to the fairly simple to replace clip.
TLDR: branded CR2032 cells would need to be more than ten times cheaper than the PP3 alkaline batteries before its even worth considering, if you were given the adapter for free.  Figure in time and materials for the adapter amortized over lets say ten years and I think its not worth it even if the cells are free!
« Reply #4 on: October 19, 2023, 01:14:23 pm »
good point - i have corrected the error of my ways   :palm:
to avoid a leaking battery destroying your favourite multimeter, or course. the meter i used for testing (above) had itself suffered a battery leak that wrecked it - it no longer zeros.
cheers,
rob   :-)
Online Fungus
« Reply #5 on: October 19, 2023, 01:21:52 pm »
Use rechargeable 9V NiMH instead, like I do.  :)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: October 19, 2023, 01:23:20 pm »
The internal resistance of 2032s is rather high - it would likely die if you turned the backlight on.
3x2450, maybe, but why?
Day Job: Mostly LEDs
« Reply #7 on: October 19, 2023, 01:28:04 pm »
the numbers i used came from the element14 website. they had packs of branded 5x CR2032 rated at 265mA.h for around $10. non-alkaline PP3 batteries ranged from 400mA.h up. the difference between 1/2 or 1/3 the lifespan doesn't really matter when the battery lasts a number of years. i generally don't worry about amortizing when it comes to my precious flukes.
self-discharge precludes use in anything not used on a daily/weekly basis. for instance, would you want to use NiMH cells to power an emergency torch that sits in the glovebox of your car for years at a time?
backlight?   :wtf:    fluke 70 series don't have backlight. these are devices that runs on the smell of an oily rag.
cheers,
rob   :-)
« Last Edit: October 19, 2023, 01:29:35 pm by robert.rozee »
Offline bdunham7
« Reply #8 on: October 19, 2023, 01:51:07 pm »
Just use an EBL 6F22 lithium battery, rechargeable or primary.  Coin cells don't sound very efficient, although it's true that type of meter doesn't exactly draw much current.
https://www.eblofficial.com/products/9v-batteries-with-battery-charger
« Reply #9 on: October 19, 2023, 04:44:14 pm »
^ this
EBL, Znter, am currently trying the brand "PUJIMAX" in one of my DMMs, seems fine. Only issue you get with these is they give a constant voltage until the internal cell is empty then just stop, so you don't get a low battery warning.
These are quite a bit less than a tenner these days, I see no good reason to use anything alse (in most use cases, YMMV).
Online Kleinstein
« Reply #10 on: October 19, 2023, 06:12:07 pm »
There are 9 V Li primary cells, often intended for smoke detectors (to get a 10 year lifespan) and similar.
Rechargeable only makes sense if empty every few weeks and not for a few years.
« Reply #11 on: October 20, 2023, 05:14:36 am »
I get a few months out of the Znter in my 87V, my work meter, remains to be seen about the runtime of the PUJIMAX, it's in a TekDMM912, and is my current daily at home.
Offline bastl_r
« Reply #12 on: October 20, 2023, 05:58:49 am »
Hello
I get a lot of 1/2AA Li batteries which have served as backup batteries for 3 years. These are regularly like new and have about 1000mAh. Three of these fit exactly into a Fluke 9V battery slot and last what feels like forever even with frequent use....
With button cells, I am concerned if they can supply the current for the resistance measurement and the continuity beeper.
« Reply #13 on: October 20, 2023, 11:53:30 am »
Li-Ion and similar make great sense if they are cheap enough and their self-discharge is so low they can hold up for several years. as an example, i've seen e-cigarettes containing a Li-Ion cell but with no means of accessing or recharging it. while rechargeable, it was cost-effective for the manufacturer use it in place of a primary cell.
also to take into account is the cumulative damage to the plastic screw bosses every time a fluke 70 series is opened up.
i still like the two stacks of 3x CR2032 idea, despite what others have said; the CR2032 has become so ubiquitous that the price of six has dropped below that of a single 9v lithium primary.
cheers,
rob   :-)
Online Kleinstein
« Reply #14 on: October 20, 2023, 04:36:50 pm »
The 9 V Li blocks are some 1.2 mAh, while Cr2032 is around 200-260 mAh. So it takes 3 in series and some 5 or 6 in parallel to replace one of the 9 V ones.
Offline BeBuLamar
« Reply #15 on: October 21, 2023, 02:55:48 pm »
The 77 is rated for 2000 hrs of battery life. So whether using 9V Lithium or 9V NiMH for the reason to prevent alkaline leakage is fine. But the cost of battery is nothing. I wouldn't bother to build a pack out of 3 CR2032's.
Offline edavid
« Reply #16 on: October 21, 2023, 03:12:50 pm »
It sounds like you are talking about the USB chargeable kind with a built in DC-DC converter.  That is the wrong choice for a DMM.  The EBL batteries that were linked are a 2S Li-ion package.  The voltage drops gradually and the low battery warning works.  The downside is that you need the special charger.
« Reply #17 on: October 21, 2023, 03:15:02 pm »
If you're worried about leakage, wrap the battery in cling film
The following users thanked this post: Fungus
« Reply #18 on: October 21, 2023, 03:44:32 pm »
Wrong how?   :-//
Offline wasedadoc
« Reply #19 on: October 21, 2023, 04:02:26 pm »
The 9 V Li blocks are some 1.2 mAh...
Nope.  Much more than that.  :)
Online Fungus
« Reply #20 on: October 21, 2023, 04:42:13 pm »
Brilliant!
Offline edavid
« Reply #21 on: October 21, 2023, 05:53:00 pm »
Wrong how?
As you mentioned, the low battery warning doesn't work.  Also they have lower capacity since there is only room for 1 cell, and shorter shelf life due to the self discharge caused by the DC-DC converter.  So they are inferior unless you need the higher output voltage, which you don't for most DMMs.
« Reply #22 on: October 21, 2023, 06:48:15 pm »
Wrong how?
A 2S Li-ion is going to have a fair bit of its capacity unused, since the BMS will let the cells go to 2.5v before cutting them off. Pretty sure the DMM will have shut off long before then.
I've had no problems with these 1S w/dc-dc convertor; as I've said I get months between charges on my 87V and I don't let it run out, I give it a charge when I remember, which is usually 2-3 months.
Offline bdunham7
« Reply #23 on: October 21, 2023, 07:43:44 pm »
Most DMMs turn on the low battery warning at about 7.0V, which means 3.5V/cell and the energy left at that point at a low discharge rate is fairly low.  That's not a bad point to make a mental note to charge the battery when you are done with the meter.  I'm not saying the version you use is wrong--unless you don't like surprise shutoffs--but I find the 2S versions to be just about perfect.  Their low internal resistance also helps prevent issues caused by ranges that draw more power (continuity, etc) when the battery is at or below the warning threshold.  Even if the battery warning comes on while you are out at the beginning of your workday, the meter will work fine for the entire day or more.  Other than initial testing, I haven't yet had a meter that actually used up even one charge with the EBL 2S 6F22 600mAh.
« Reply #24 on: October 22, 2023, 12:21:23 pm »
I only had that happen the once, and it was after such a long time I'd completely forgotten about the battery, probably 6 months or so.
Ultimately the best battery is the one that suits your own use case best.
