Author Topic: Oscilloscope temperature sensor or transducer  (Read 952 times)
Offline SG-1Topic starter
« on: October 10, 2019, 03:16:38 am »
I am in need of a temperature sensor or transducer for an oscilloscope.
Currently running an experiment with a 15A circuit breaker in an elevated ambient temperature.  Seeing how an elevated ambient temperature effects the trip curve,
I can measure & record the current over a 12 hour period (fluke 189), but cannot record a correlated temperature reading.
My two channel scope (fluke 196C) seem to be part of the solution, but having trouble finding a temperature probe for the second channel.
The temperature extremes range from 20 to 75 degrees C.
Would like to find a plug & play solution.
Advice is a dangerous gift, even from the wise to the wise.
Offline KaneTW
Re: Oscilloscope temperature sensor or transducer
« Reply #1 on: October 10, 2019, 05:50:57 am »
I would just record it separately with some data logger and correlate when processing the data.
The following users thanked this post: SG-1
Offline 2N3055
  • Country: hr
« Reply #2 on: October 10, 2019, 08:18:28 am »
You need one of those temp sensor signal conditioning modules that take temp sensor as input ( TC, RTD or thermistor) and outputs 10V output.
Or like KaneTW said, simply log it separately and correlate data. It doesn't have to be synchronised to microsecond.
