Author Topic: Using a Hacker RF one as an oscilloscope  (Read 1431 times)
Offline daslolo
  • I saw wifi signal once
« on: April 24, 2018, 09:58:59 pm »
I don't know if it makes much sense but I saw clean signal from 1 to 6000 Mhz and wondered if anyone was using this cheap gear as oscilloscope and spectrum analyzer.
« Last Edit: April 24, 2018, 10:00:37 pm by daslolo »
nine nine nein
Offline ataradov
    • Personal site
Re: Using a Hacker RF one as an oscilloscope
« Reply #1 on: April 25, 2018, 03:44:51 pm »
It has 20 MSPS ADC, so the actual bandwidth of the signal will be pretty low.  You can do a spectrum analyzer, but it is impossible to make an oscilloscope out if it.
And that is not to mention that a scope that can't see blow 1 MHz is sort of useless.
Alex
Offline daslolo
« Reply #2 on: April 25, 2018, 09:24:01 pm »
That's right, now I see why it's no good for oscillo. Weird that Ossmann said in 2014 that it's doable...
nine nine nein
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: April 26, 2018, 12:11:56 am »
even if you can tolerate > 1MHz signal, i suspect there is no phase information for the displayed FFT from HackRF, (RSSI or magnitude info only), meaning if you want to generate time domain signal through inverse FFT, then you have to guess the spectrals' phases, so the t-domain shape can be anything.
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
