Author Topic: Using DC electronic load for 50Hz AC Sinewave  (Read 2647 times)
Offline peter_mccTopic starter
« on: November 07, 2022, 06:39:59 am »
I want to use an electronic load to test outputs that are 50Hz sinewave waveforms coming from a transformer. All the AC Electronic Loads I can find are really expensive.
Can I run the output through a bridge rectifier and use a DC load in constand resistance mode? I realise there will be issues around the zero crossing point.
I'm looking at something like the Korad KEL103/Tenma 72-13200 or Siglent SDL1020X.
My only concern is how well the constant resistance mode can track the changing input voltage.
Offline Kleinstein
Re: Using DC electronic load for 50Hz AC Sinewave
« Reply #1 on: November 07, 2022, 07:22:30 am »
Some electronic load implement the resistance mode in software. So it may be slow in adjusting the current in reponse to a changing voltage. So the load would not be very much like a constant resistance.
One may be able to improve a little by using a parallel normal resistor to take over much of the current. So the electronic load with rectifier would only do part of the load.
Otherwise, just a set of resistors to combine in parallel or series may well be an alternative to an electronic load to simulate resistors.
Offline Fungus
« Reply #2 on: November 07, 2022, 01:26:12 pm »
I don't see why not. It may be exactly the type of load the transformer will be connected to anyway.
(unless you have a specific use case for these transformers that isn't that)
Most bridge rectifiers in the world have a big capacitor across the output to smooth it out.  :)
Offline alm
« Reply #3 on: November 07, 2022, 03:42:29 pm »
How important is the shape of the current to you? Does it need to be sinusoidal and in phase with the voltage (power factor = 1)? Or does it not matter as long as the average current is correct?
I don't see an issue with a full-bridge rectifier as long as the voltage is high enough that the drop in current around the +/- 1 V range doesn't matter. But I'm not convinced the load will be fast enough in constant resistance mode to track a 50 Hz signal, because many loads will implement the constant resistance control loop in software to save costs. I don't know these specific loads, and they don't seem to specify constant resistance bandwidth. I think you'll have to test it: feed a 50 Hz signal into a load through a bridge rectifier and a low value series resistor, and with a scope measure the voltage across the load and across the series resistor (careful how you connect the ground leads).
If you don't care about the shape of the current signal, then a cap in parallel with the load, as Fungus, would make the job easier on the load, but would make the current draw very non-sinusoidal.
The following users thanked this post: peter_mcc
Online gf
« Reply #4 on: November 07, 2022, 05:21:08 pm »
Are the input terminals actually isolated/floating? Or is one of them earthed?
« Reply #5 on: November 07, 2022, 11:08:03 pm »
Thanks everyone.
That is my major concern - nobody (at least in my price bracket) seems to specify the bandwidth for "constant resistance" mode like they do for constant current/constant voltage.
I was hoping someone else had tried it! I haven't bought the DC electronic load yet and if it doesn't react fast enough it is of no real use to me.
I'm trying to do production testing of a product and need 4 different currents (upper/lower bounds for on & off states). I could do it using resistors but it would be affected by mains voltage variations.
I wish someone made a cheap AC electronic load - the cheapest I can find is a second hand Koritsu for about $US3k.
Offline alm
« Reply #6 on: November 07, 2022, 11:18:25 pm »
Something that could work for loads that support analog programming, or power operational amplifiers like Kepco BOP or Lambda BOSS, would be to feed them a divided (and if necessary phase-shifted) version of the voltage signal as current programming signal. In the case of a unipolar load, a rectified version of the voltage signal. I have never tried it, but it might yield better bandwidth than constant resistance mode, especially if it's CR is done in software.
For a business application where time and reliability are an issue, I would not bother coming up with improvised solutions but buy a proper instrument designed to do this job.
« Reply #7 on: November 08, 2022, 10:38:52 am »
It needs to be reasonably close to a sine wave.
I agree in principle except that the "proper instrument" is several thousand dollars which I'd rather not spend if possible.
Offline Fungus
« Reply #8 on: November 08, 2022, 12:17:18 pm »
In that case there's probably no shortcut.
I guess you could buy a selection of big power resistors, put them in parallel in different combinations, and ... heat them up.
It's not as easy as dialing a number on a screen though.
the "proper instrument" is several thousand dollars.
Maybe there's a reason for that.  :)
Online nctnico
« Reply #9 on: November 08, 2022, 01:58:43 pm »
To the OP:
What kind of range & adjustment accuracy do you need? If making a DIY solution is an option, then you could consider building an AC load using resistors and opto-relays (or conventional relays). By putting more or less resistors in parallel, you can create different resistance values.
For one of my customers I have designed & build a bunch of high power DC loads that need to run 24/7. These are about 2* 1.2kW in a 3U 19" case. I have used resistors bonded onto a metal base (WDBR series from TE):
These can run hotter compared to resistors (smaller fan cooled heatsink) and are way more reliable as well.
In my case I have used MOSFETs but for AC purposes the easiest way is to go for (opto) relays based on MOSFET or Triac. Be sure to add some TVS diodes as well; at high currents power resistors have enough inductance to create a nasty spike at turn off.
« Last Edit: November 08, 2022, 02:00:35 pm by nctnico »
Offline alm
« Reply #10 on: November 08, 2022, 03:00:51 pm »
If your power requirements are modest (dozens to maybe 200W), there are power resistance decades, like the Clarostat 240C and those made by Time Electronics, that are a more convenient to use than a bunch of power resistors and clip leads. I believe there are also versions with relays that can be automated. You do need to pay attention to how much power they can handle depending. Usually each decade is rated for a certain current, so make sure you stay within that. For example for the Clarostat the 1 Ohm decade can handle 5 A, so at 1 Ohm it can handle at most 5 A^2 * 1 Ohm = 25W, while with the first decade set to 9, it could handle 5 A^2 * 9 Ohm = 225W.
I did a quick test with a Kikusui PLZ-300W load which implements constant resistance using an analog feedback loop (see manual with specs and theory of operations here) set to 180 Ohm, a standard bridge rectifier and a HP 33120A function generator set to 50 Hz sine 20Vp-p (with 50 Ohm output impedance). I wouldn't want to use it for AC testing. Yellow is the AC voltage going into the bridge rectifier, blue is the current going into the bridge rectifier measured with a current probe (Tek P6302 + AM503B, vertical scale on scope is correct), gray is the voltage from the bridge rectifier going into the load (same scale as yellow), and white is the current from the bridge rectifier flowing into the load (same scale as blue). So clearly the load is quite slow in responding to the abrupt voltage changes even at low current levels, like the overshoot after the zero crossing:
The bridge rectifier itself is not a problem as long as your voltage is high enough, and could be improved somewhat if you'd use Schottky diodes instead of standard rectifier diodes. Here is the same test showing the AC voltage and current when replacing the load by a 150 Ohm resistor:
« Last Edit: November 08, 2022, 03:11:48 pm by alm »
Offline unknownparticle
« Reply #11 on: November 08, 2022, 03:15:01 pm »
Very coincidentally I was going to try this as a load for testing audio amps, think I'm going to test it out on a relatively low powered single board power amp first to see what happens ???  I have an old school DC  electronic load by ACDC Electronics, a real beast from the '70's that can handle upto 750 watts, and also a Kikusui 300 watt unit which is much more recent. Should be interesting.
DC coupling is the devils work!!
Offline alm
« Reply #12 on: November 08, 2022, 03:26:47 pm »
I'm a little bit surprised it's performing so badly, because the PLZ-300W manual (page 16, fig 2-3-4) shows a flat impedance up to 1 kHz.
« Reply #13 on: November 08, 2022, 03:42:42 pm »
Interesting. I have the PLZ-303W, I'll check the specs on that.
« Reply #14 on: November 10, 2022, 10:52:00 am »
Thanks for doing that - unfortunately it is as I expected and didn't work  :'(
I've come up with another solution using a fixed resistor bank and a programmable AC power supply which I have.
Thanks everyone for your input!
Offline Geoff-AU
« Reply #15 on: November 10, 2022, 11:45:43 am »
Good that you found a solution.
I was noodling around about a programmable constant resistance load for another project and I think I've come up with something worth trying.  I need to build it and see if it actually works.  Might help you next time ;)
