Author Topic: Using the DE-5000 to measure stray inductance of low-value wirewound resistors  (Read 1154 times)
Offline cvancTopic starter
Hi all-
Anyone have experience using the DE-5000 to measure the stray inductance of low value wirewound emitter resistors?
I've got a few different emitter resistors here and will post some measurements, but I'm curious if others have done this and found it A) accurate and B) useful?
Thanks.
Offline chronos42
that works well with the DER EE 5000.
Set the meter to LS/LP  with the blue LCR AUTO key, then with the SER/PAL key to LS and D/Q/ESR/phi to ESR. Set the frequency to 100kHz.
Online coppercone2
I think the DE-5000 has accuracy specs in the manual relating to the accuracy of measurements at particular impedances. I don't recall if it has accuracy specs of the parasitics though.
Secondary Parameters Accuracy in manual has formulas for accuracy. would be nice if someone bothered to make a graph
« Last Edit: October 15, 2018, 08:09:31 pm by coppercone2 »
Offline evava
  • Country: cz
I have experience using my DE-5000 to measure stray inductance of low value wirewound resistors, but it is not pleasing experience and my DE-5000 behaves exactly the same way as in this post:
(sorry for cross linking) https://www.eevblog.com/forum/testgear/strange-behaviour-with-my-de-5000/msg897162/#msg897162.
So  :-//
I think there are better meters for this task.
Online coppercone2
he said he had problems with the kelvin clips. I noticed this too and I had to resolder my alligator clips.
I might do experiments on mine in a few weeks, but I have nothing good to compare it to.
I can actually use the formula to calculate error based on the manual.
oh yea, this thing also  got funky with me before from batteries IIRC.
