Author Topic: UT60S change to current measurement without touching the button  (Read 1034 times)
Offline ndarjo21Topic starter
  • Country: id
« on: January 29, 2024, 07:18:05 pm »
This 6 month multimeter have strange behavior. It change to current measurement mode itself. When teardown the meter i didnt see any damage. After covering trace below current mode button with a isolation tape(black tape) i havent encounter this problem again.
https://youtube.com/shorts/6ggqvz2dYH4?si=97CbYRASmro-hcVv
  • Country: id
Re: UT60S change to current measurement without touching the button
« Reply #1 on: April 13, 2024, 05:20:23 pm »
it happen again. even the tape still in the place. other mode button didnt repsond. just backligh/power, hold, range, hz/% which give respond
Offline coromonadalix
« Reply #2 on: April 13, 2024, 05:21:49 pm »
keypad contaminants ??
Offline sonpul
  • Country: ua
« Reply #3 on: April 13, 2024, 09:21:16 pm »
UT60S has detection of correct probe connection. Perhaps the two separated halves of the uA connector are shorting each other. When they close, they command the multimeter to turn on the current measurement mode.
The contact plates themselves can short out, or something metal could get in there.
« Last Edit: April 13, 2024, 10:15:18 pm by sonpul »
  • Country: id
« Reply #4 on: April 14, 2024, 01:53:25 am »
i dont have another multimeter so didnt know how to diagnose it. but the pcb seems clean. i already resolder allmost all component with new solder in case there are bad connection but the problem still persist
  • Country: id
« Reply #5 on: April 14, 2024, 05:27:26 am »
after removing the transistor/mosfet/anything. now it work in V, mV and resistance mode. the problem when measuring voltage is 500mV floating in V mode
« Last Edit: April 14, 2024, 05:57:16 am by ndarjo21 »
  • Country: id
« Reply #6 on: April 14, 2024, 10:03:44 am »
shorted probe in resistance or continuity show 600 ohm. in diode mode 0.1v
« Last Edit: April 14, 2024, 10:21:00 am by ndarjo21 »
