Hi everyone.
I'v read a lot of related topics, viewed reviews but realy can't make the final desition.
I need DMM "to go" for home use, amateur electronics, automotive electronics and electrics.
Features needed:
- accuracy\speed not lower then ut61e has
- quick analogue bar graph
- 22k counts or more (depends on accuracy)
- quick and correct continuity test
- temp is not necessary, but nice if has
- datalogging (offline is better, offline+BT is best)
- reasonable functionality set
-20A possibility
Owon is closest, but i don't shure about it. It is not so popular, like 61e, so this confuses.
61e+ has problems with a continuity: It don't stops a long beep on a break if was short more, than 1 second (if I understood correctly). Can this be fixed? Firmare update? Third part firmware?
61e is old and has no many features 61e+/owon do.
I guess all will finish with bm867s/869s, but may be there is a reasonable way below 100$... I like 867/869, but just don't need their functionality.
Thanks.
